Lurching on hard acceleration
Old Mar 26, 2019 | 05:42 PM
Space387's Avatar
Space387
Default Lurching on hard acceleration
I have been working on a friend's 96 Coupe with an A4 transmission. Today I replaced the fuel pump to fix the no start issue and get it driving for the first time since he bought it a month or two ago. I never met the past owner so I don't know how long it sat before that. As of right now it starts and idles wonderful, revs fine and feels strong but when accelerating it lurches like it is unsure of what gear to be in. If you ease into it and stay under say 1/4 pedal( ish wasn't data logging) it changes gears just fine. If you roll into it slowly it gets up and goes just fine but if you open the taps, even a little, the car lurches like a really hard down shift.
I have HP tuners available but cant seem to find trans info and being an OBD2 car I'm not as familiar with what other programs I could use to try and diagnose without going to a shop. Thanks in advance.
Old Mar 26, 2019 | 06:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What does it feel like when you get on it heavily from a start?
How high will it rev in D before bogging down while holding with the brakes?
Old Mar 26, 2019 | 06:52 PM
Space387's Avatar
Space387
From a dead it runs to about 4k lurches, it gets back and pulls right away but I dont stay in it because it's not my car to break. Haven't tried power braking and wont be able to get back to the car for a few days sorry
Old Mar 26, 2019 | 07:52 PM
383vett's Avatar
383vett
See if it does it with the gear selector in 2nd. If after 4k it still "lurches", then it's not the tranny. It's something with the motor.
Old Mar 26, 2019 | 08:03 PM
Space387's Avatar
Space387
Trans fluid is proper level and a fresh red color so it like like someone recently changed it. Manually changing the gears doesnt remedy the lurching and it's not rpm dependent. When rolling it is as soon as you give it a decent amount of gas regardless of your speed gear or rpm. The 4k was the highest I got it to go in 1st before lurching. Checked the sensors with HPtuners and everything engine wise looked correct. Tps responded properly, map the same and MAF. Temp sensors are reading within reason too
To Lurching on hard acceleration
