Code 23 MAT
Old Mar 27, 2019 | 03:59 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
Default Code 23 MAT
85 Z51 Auto. Getting a soft Code 23 meaning sets code but light doesn't stay on. Checked per FSM and have 5 volts and a resistance of .700 k ohms which if my math is correct that is 700 ohms. Anything over 4 volts is good. What isn't matching is ohms. Scan tool showed 203 degrees F. Chart has 210 f-185 ohms, 160f-450 ohms, 100f-1800 ohms. So it looks to me the resistance is too high for the temp reading. I double and triple checked the readings after clearing code, driving, code reset. I think I have a bad or weak sensor. What say you? Need more info?, just ask. Under plenum so tough to replace? These can be relocated correct? If so can you post a link or lmk, either way, replace or relocate? TIA.
Joe K
