89 firebird 5.7 tpi
Old Mar 28, 2019 | 02:37 PM
bud40oz's Avatar
bud40oz
Default 89 firebird 5.7 tpi
what is the difference of the 89 firebird tpi engine compared to a 91 vette i know the aluminum heads are not of the firebird 5.7 but other than that what are the difference, i can get a complete engine and 4l60e trans for 300 bucks with all of the tuned port injection stuff
Old Mar 28, 2019 | 04:23 PM
KyleF's Avatar
KyleF
buy it now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 28, 2019 | 05:27 PM
ekistler1971's Avatar
ekistler1971
Default Firebird tpi
The big difference is the egr setup. Corvette is external. Gen 3 tpi's are internal in the intake manifold. Probably easier to swap your intake setup.
Old Mar 28, 2019 | 06:27 PM
KyleF's Avatar
KyleF
Originally Posted by ihatebarkingdogs
The center plenum is different on the Firebird to clear the lower hood line. IIRC the Firebird was rated 5-10 HP lower than the Camaro with the same engine because the Firebird's plenum is more restrictive.
Got a reference on this?
Camaro/Firebird had different intake plumbing to the filter. I never heard of them having a different manifold nor noticed a difference after owning both.
Also never remember seeing a published hp difference between comparably equipped cars.
Old Mar 28, 2019 | 07:37 PM
bud40oz's Avatar
bud40oz
i would be wrong on that trans though wouldn't i? after thinking about it an 89 would be 700r4 not 4l60e
Old Mar 29, 2019 | 09:25 AM
KyleF's Avatar
KyleF
Correct, and 89 automatic would be the 700R4. No 4L60E until LT1.
Old Mar 29, 2019 | 10:08 AM
KyleF's Avatar
KyleF
I don't remember where I read this. Maybe they made it up. But I didn't. I distinctly recall reading this somewhere. Around the year 2000 I helped a guy do a 87 Firebird TPI into a 58 Bel Air wagon. I did the swap, engineering, fuel system, wiring, etc. I remember that at a later date I read that the Firebird engine wasn't as strong as the Camaro engine, it was rated less, and that the plenum / hood line was the reason. I remember thinking "too bad we used a Firebird. We didn't know this at the time". The guy ended up selling the car only a few months after I finished it for him.
I know the hood lines and bumper heights were different. This did dictate a difference in air intakes. The TPI Camaros set over and in front of the radiator support , two fileters that fed 1 tube with a direct shot to the throttle body. The Trans Am TPIs had a elbow and the filter set to the side by the finder. Originally this was a mess up box type junction that later was replaced by en elbow.
I would say there were no differences in the cast manifold or runners. I can't "prove" this, but your post was the first I ever heard of anything being different about the manifolds.
I can also confirm the external EGR and slightly different ECM mapping due to aluminum heads when comparing to the corvette.
To 89 firebird 5.7 tpi
