Air Pump Supercharger
Mar 30, 2019 | 09:15 AM
Ok, I know there are people who do Air Pump Deletes when removing old worn out heavy power robbing Cats, so they just clean up everything in the engine compartment associated with it, including the Air Pump. But what would happen if you just route the discharge of this positive displacement pump just ahead of the MAF. Isnt more air flow what is recomended at least for an 87 to increase performance. Thoughts??
Mar 30, 2019 | 09:22 AM
Mar 30, 2019 | 09:31 AM
St. Jude Donor '05
Its not going to help you at all unfortunately
Mar 30, 2019 | 11:39 AM
Mine's just pumping to the silencer or atmosphere. I think the pump looks better than those modified pully's!
Mar 30, 2019 | 11:41 AM
Air is Air, you're saying the trade off between the horsepower required to run the pump and return is'nt worth the trouble?
Mar 30, 2019 | 11:42 AM
Cruise-In II Veteran
Why not install a mild SC into that location.
Mar 30, 2019 | 11:48 AM
I guess I'm staying close to stock on this car, I have a green air filter to put in, and maybe new fuel injectors in the future.
Mar 30, 2019 | 06:20 PM
I dont see how it would really help, its not much air being forced into the manifolds.
But you can try it, you might be the first.
Mar 30, 2019 | 07:31 PM
It's not going to help and it's unfiltered so it could actually hurt.
