throttle body leaking Smoke test
They can be re-bushed pretty easily and the kits are available on Ebay.
Here's a thread on the matter:
http://garage.grumpysperformance.com...bushing.10995/
Or, it is an excellent excuse to spend the money on an aftermarket TB if you want to.
Be sure to get the early one, because you need the TV cable provision to run your transmission pressure controls.
The one I have I bought used, and I haven't installed it yet. It is a "Professional Products" I got from Pwnage, but I don't think they are in production any longer.
If it runs okay, you can always leave it like it is for now. But it is a vacuum leak. If you have idle issues that can certainly affect it.
On the newer cars you might be able to check the IAC counts and gauge the extent of the leak, but on our cars they enter "field service mode" when you connect the scanner and mess the datastream all up.
I do know that once they begin to wear, they get much worse with time. I have an extra stock body upstairs with really severe slop in it. So bad it rattles. Probably enough that it would never idle correctly regardless of any blade adjustment you made to correct it. So, replacing it or rebushing is probably in the future soon anyway.
You will absolutely want one for the 85-92 model years for the transmission pressure controls. It has to have those.
If you buy another tb, used are new, make sure it has the correct linkage on it. I think in 88 they changed.
I have bought several over the last several years, both new and used and was not happy with ANY of them. Most of the new cheaper ones have problems with the throttle plates not going back to idle after the engine warms up. It has happened to me numerous times
Fix yours and you will be much happier
https://www.corvetteforum.com/articl...ps-idle-speed/
BTW, I never could get mine to idle at anything below 650.
But a little fiddling and you can make it work.
You might verify timing too.
Also, being an 85, if you have performance trouble you can't work out, you might want to check other things..
Among them: Water in the gas tank. (Took me forever to find this. Nobody expects it?) The fuel injectors are total crap in 85. (Bosch III's will retrofit if done right) The compression, of course. Other sensors. Even the ECM can be a problem. (I'm on my third) Etc..
Our cars are old and cranky, so it can take a little doing to get them all smoothed back out and running right. You'll get it.
Edited to add: There's an EST connector you unplug to set/check base timing. It's a single wire connector by the distributor.
The gauge might even help resolve the potentially loose throttle rod issue.
I would take some play dough or soft clay and try to stop the leak on the throttle body shaft first to be sure that this particular leak is indeed the cause of your idle fluctuations. If you roll the clay into a string and wrap it around the shaft just to see if you can block the vacuum leak. If you idle smooths out and stabilizes at one speed then you are sure your bushings need to be replaced!
Years ago my throttle body was sticking and leaking anti-freeze so I bought the Professional Products throttle body. It works just fine and no real difference from the factory unit in performance. I should have just fixed my old throttle Body had I been smarter....
By the way!
Welcome To The Corvette Forum!
Good Luck and be sure to tell us what happens!
ctmccloskey a.k.a. Chris
