Hooker are on the way!!
Old Nov 3, 2002 | 06:45 PM
Corvette0096's Avatar
Corvette0096
Default Hookers are on the way!!
2149's and y pipe. Now for the questions, What is a good gasket to use? Head to headers? Does the kit come with bolts?
TIA
Rich
[Modified by corvette0096, 3:21 PM 11/3/2002]
Old Nov 3, 2002 | 06:47 PM
J Z06's Avatar
J Z06
Default Hooker are on the way!!
Fel Pro's are on mine(LPE's) from the head to header. There's no loc tite on my bolts either I found out. They're just "Cranked" I was told!
Wait'll you feel how much better the motor is going to breathe once those puny manifolds come off. :yesnod: :smash:
Old Nov 3, 2002 | 06:49 PM
Corvette0096
Default Re: Hooker are on the way!! (JD 90 383)
I am rubbing my hands waiting. That should be good for 5-7 ponies. Felpro 1404?
[Modified by corvette0096, 2:51 PM 11/3/2002]
Old Nov 3, 2002 | 06:50 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Hooker are on the way!! (corvette0096)
Mr. Gasket sells a very nice copper gasket. They come with lock washers which I didn't even use. I used ARP header bolts and lubricated them with ARP assembly lubricant. So far none of them have even begun to back out and it's been several months.
Old Nov 3, 2002 | 07:18 PM
GlockLT4's Avatar
GlockLT4
Hmm.. change that to "Hookers" and send them to my place... (either the exhaust pipes or the hoe's will work :jester )
Old Nov 3, 2002 | 07:22 PM
Corvette0096
Default Re: Hooker are on the way!! (GlockLT4)
One way of the other they are both spendy..
Old Nov 3, 2002 | 07:57 PM
blk90rdstr's Avatar
blk90rdstr
Youre gonna get thousands of veiws on this post with a title like that. :D :lol:
Old Nov 3, 2002 | 08:05 PM
Caboboy's Avatar
Caboboy
Default Re: Hookers are on the way!! (corvette0096)
Here's how they come. Congrats!!!!!! :cheers:
Edit: OK, I'm gonna try to get these pics to stick again :confused:
[Modified by Caboboy, 7:43 AM 11/4/2002]
Old Nov 3, 2002 | 08:09 PM
Corvette0096
Default Re: Hookers are on the way!! (Caboboy)
Sweet they come with everything. You have any problem with the gaskets leaking?
Old Nov 4, 2002 | 12:57 AM
gtsyellow's Avatar
gtsyellow
perceys double thick aluminum, for the header and the summit aluminum for the collector, stop by and look at mine closely sometime, they are by far the best i've used yet & that would include fel-pro, sce and the generic graphite composite.
Old Nov 4, 2002 | 09:36 AM
Corvette0096
Default Re: Hookers are on the way!! (gtsyellow)
Aren't you the same guy that had that lifter that went bad and found out it was just that your headers came loose? :jester I think I will try what come with the headers unless someone say that the ones that come with the kit are junk.
Old Nov 4, 2002 | 09:37 AM
Caboboy's Avatar
Caboboy
I haven't installed them yet, they're sitting in the garage next to the new motor.
To Hooker are on the way!!
