Belt tensioner pully question
Old Apr 5, 2019 | 02:48 AM
MaineJim's Avatar
MaineJim
Default Belt tensioner pully question
Hi all,i need to replace the belt tensioner pulley on my 1992 LT1 and have a question.
Is the bolt that holds the pulley a left handed thread? as in to loosen it turn clockwise ? or is it counterclockwise?
Thank you in advance.
Old Apr 5, 2019 | 12:30 PM
Kevova's Avatar
Kevova
Left hand thread for pulley bolt, it probably has blue loc tite on it also. Clockwise to loosen. Counter clock wise to tighten and release tension on belt.
Old Apr 5, 2019 | 01:41 PM
KyleF's Avatar
KyleF
I don't remember this being the case... but its been about 9 months since I replaced mine. Look at how it is installed on the car. If you put a wrench or socket on it to push it over for the belt install/removal that will be the direction that tightens it. Opposite will remove it.
I had to pull mine out to replace the pulley. This required I remove the power steering pulley with a puller to get in there.
Old Apr 5, 2019 | 06:03 PM
MatthewMiller's Avatar
MatthewMiller
I agree. To add to this, the FSM for my 96 doesn't have any notes about it being left-hand threaded. You'd think they would say something if it were.
Old Apr 5, 2019 | 09:58 PM
MaineJim's Avatar
MaineJim
Ok guys thank you for your input,my FSM doesn't mention a left handed thread either.
To Belt tensioner pully question
