Gen 4 Timing
Old Apr 9, 2019 | 05:44 PM
wlbuckles's Avatar
wlbuckles
2nd Gear
Default Gen 4 Timing
Bought a coupe with 1992 to1996 LT1 installed w/ edelbrock carb. Ant idea on how to set timing ?
Old Apr 9, 2019 | 07:07 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Does it have conventional distributor? Or is is still using the OPTI and ECM?
Old Apr 9, 2019 | 07:26 PM
wlbuckles's Avatar
wlbuckles
2nd Gear
Default Timing
Not a conventional. Electronic. Puzzled, harmonic balancer has 2 pullies with no marking for timing.
Old Apr 9, 2019 | 07:53 PM
Whaleman's Avatar
Whaleman
If opti the timing is set by the computer
Old Apr 9, 2019 | 10:21 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
By "conventional", I meant that it is mounted at the rear of the engine, through the back of the intake manifold.
Old Apr 10, 2019 | 11:47 AM
RandomTask's Avatar
RandomTask
If it's an Lt1, the timing is controlled by the computer.
The only timing that can be physically set is b/w the crank and the cam. This is done w/ the cam over off via the timing chain. Adjusting this would cause serious issues.
The only other timing that can be adjusted is via the ECU.
Old Apr 10, 2019 | 12:52 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
If it is running a carb I doubt the computer is still controlling the timing.
Find top dead center on the #1 cylinder and mark the balancer where the pointer is. This is your 0° mark. When running at idle, you can adjust the distributor by turning it clockwise and counterclockwise until you reach the desired advance setting via a timing light. If the pointer doesnt have marks on it either you may need a timing light that can advance the strobe built in. This of course applies if the distributor is in the back of the intake and "conventional" as TOM400CFI suggested.
If it is running off the opti then you can still check the timing using the method above, but adjustments will require tuning via a computer.
To Gen 4 Timing
