Help, Car Won't Start
Old Apr 17, 2019 | 09:05 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Default Help, Car Won't Start
Hey everyone. It's been awhile since I've been here. Well, I have a 1996 auto coupe. It's not my daily driver so I only drive it maybe 2-3 times a month otherwise it sits my driveway. Since the last month, I've had trouble starting my car. I thought maybe something electrical got wet in the rain we got the past month. It will just keep cranking without starting. The days that I can get it started, it works fine the whole day. I can start it and driving is completely normal. I know that there are 3 things to start and keep running the engine. Air, fuel and spark. I believed that maybe my plugs got wet, but it's been a few days without rain and the car still won't start. Could it be the fuel pump/sender? If it was the fuel pump, wouldn't loss of power or hesitation be present on the days the car starts. When I can get it started, everything is normal. I can floor it and feel now loss of power or hesitation. What should I do to narrow down what my problem could be? Thanks in advance, Ed.
Old Apr 18, 2019 | 11:39 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I would start with a timing light on #1 wire then check fuel pressure, see if anything shows up with the usual suspects.
Old Apr 18, 2019 | 04:12 PM
Y-bodluvr's Avatar
Y-bodluvr
Sounds like your OPTISPARK distributor got wet and or has failed you can open your hood and let the sun dry it out or taking a hair dryer to it if your water pump isn’t leaking there’s a slim chance that may fix it but being that this didn’t happen recently it’s probably already dry and you just have to replace it..
Old Apr 19, 2019 | 01:16 AM
skinnyt's Avatar
skinnyt
it could be bad---
icm
coil
optispark---!!!! (sounds like this prob)
fuel pump
check for spark first
To Help, Car Won't Start
