Help - Low Coolant Light
Old Nov 4, 2002 | 05:07 PM
Alphatoto's Avatar
Alphatoto
Default Help - Low Coolant Light
I occassionally smell coolant after I shut down. (Not the heater coil, its coming from the lower part of the engine bay)I don't see a leak anywhere but last week the low coolant light went on, but when I looked the resovoir is about 25% full. Car's running temp seems ok. 170 on the freeway, 210ish in stop and go.
Any thoughts on whats up? :seeya
Old Nov 4, 2002 | 05:13 PM
Greenvette's Avatar
Greenvette
Default Re: Help - Low Coolant Light (Alphatoto)
You might want to look at the oil cooler lines which go into the oil filter/adapter assembly.
[Modified by Greenvette, 3:15 PM 11/4/2002]
Old Nov 4, 2002 | 05:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check all hoses, under the water pump around the oil cooler if so equipped and around the intake base. Don't foreget to check that small steam hose going from the rear of the base to the heater hose.
Old Nov 4, 2002 | 05:26 PM
Steel Blue 91's Avatar
Steel Blue 91
Also, check at the back of the intake on both sides.
Old Nov 4, 2002 | 07:01 PM
MITCH's Avatar
MITCH
i had this happen to my car and the head gasket was shot the car never run hot but i would smell coolant. it crack 1 piston on me but it did not damage the block. my coolant light was going crazy also.
hope this helps
mitch
Old Nov 4, 2002 | 07:13 PM
Ender85's Avatar
Ender85
Default Re: Help - Low Coolant Light (MITCH)
Happened to me - it was the water pump. Check coolant when colt - it should be up to the neck of the radiator. It could be a faulty sensor - have you seen leaking coolant on the ground?
Old Nov 4, 2002 | 07:34 PM
sunrise.cm's Avatar
sunrise.cm
Coolant resovoir 25% full is about where it should be. Assuming your low coolant sensor is OK (radiator was realy low), you might check your radiator cap 1st. It's cheap and easy. Make sure there are no leaks in your coolant recovery hose. Next step might be intake maifold. Issue is that the leak might be evaporating as quickly as it leaks, making it hard to find. A coolant pressure tester (NAPA $70) makes it easier. You can pressurize your coolant system cold and know that it does or does not hold pressure. If it does not you will see a low coolant light as there will not be vacuum to pull coolant from you resovoir back into the radiator as it cools. That's why is important to look at the coolant recovery and radiator cap. Other possibilities are hoses, water pump, and oil cooler. Water pump leaks are like intake - can be hard to find because of evaporation. Good luck :smash:
Old Nov 4, 2002 | 07:48 PM
eddieL98's Avatar
eddieL98
hope this helps
mitch
here too but it didn't damage anything. i just notices some grey smoke in the mornings. no leaks anywhere until the heads were pulled and saw the gasket was worn in one spot.
Old Nov 5, 2002 | 08:22 AM
ToniH's Avatar
ToniH
Mine started excatly like that too with the same results, blown gasket.
Toni
Old Nov 5, 2002 | 01:26 PM
Alphatoto's Avatar
Alphatoto
Default Re: Help - Low Coolant Light (ToniH)
Thanks for yor suggestions, I'll follow up. Hoping its not the gasket since it should only have about 25k miles on it and I make sure the engine never gets too hot.
To Help - Low Coolant Light
