Help a girl out...
The optispark is keyed, you'd have to go out of your way to screw up the timing.
-- Joe
Anyway, you're right. You can't screw up an opti install unless you REALLY try...and even if you did...the ECM ain't never gonna "re-learn" what you screwed up.
OP or her mechanic need to take a closer look at the OPTI. If I were diagnosing that car, I'd hook up a scan tool, run the car, and when the symptom occurs, I'd be looking at the low res, high res and tach signals,very closely.
OP, does the tach needle jump all around spastic-ly when the engine is missing and acting up? If so....that's your Opti.
But yeah, they need to diagnose it properly in a shop. My '94 was doing something similar last spring, and it was a faulty wire to the ICM.
-- Joe
Yes I know the original optispark’s arent made anymore but if you get lucky on ebay - sometimes you can find an old man selling an NOS spare he may have in a tattered box. You have to know the right questions to ask the seller of it.. expect to pay $350 plus to get an NOS unit. Price alone is not a guarantee of a good quality optispark - for example the expensive MSD optispark (non-OEM replacement) also has an optical sensor known to fail.
you need an optispark with the original mitsubishi optical sensor. The cheap copies dont hold up under the heat / ozone of an engine environment.
Questions to ask: does he have 1 or 10 he is selling? If its 10, then its probably not NOS unless theres a good story behind (ie. Take offs off of old crate motors)
Is the cap the tan one or the opaque/charcoal green one that you can see the wire traces through? The NOS OEM caps were the tan ones that you cant see the spark plug wire traces through
You can post you are looking for an OEM one in the for sale section here or other f body or b body websites.
Other options are there is a guy in ohio - optidoc, that takes a msd optispark / installs a genuine mitsubishi sensor in it. He also tests to make sure it works.
remanufactured by GM is not preferred as they do a great job replacing seals , bearings, but ‘recycle’ the old optical sensor. But Id rather have a GM remanufactured - as long as it has the original working mitsubishi optical sensor vs a brand new china optispark with a cheap repro optical sensor.
id rather have a used known to be working oem optispark (with a mitsubishi optical sensor) vs a chinese repro optispark.
you can take the opti spark apart and look for mitsubishi symbol on optical sensor before install if in doubt.
finding a reproduction optispark ‘with a good warranty’ is not a good option bc your warranty does nothing for you when you break down due to an optical sensor failure from a non mitsubishi optical sensor failure - let alone the inconvenience/cost of spending hours replacing that hard to get to part.
The optispark gets a bad rap for no reason. The gen 2 optisparks usually dont fail unless the vent system clogs. The gen 1 92-94 optisparks need a vent added to make them reliable like gen 2
if you had the oem part on this 96, im surprised it went bad.ive heard of some beating failures, but thats it. Many people here make mistake of proactively replacing a good oem optispark with a chinese unit thinking they are doing preventative maintenance.
Really the only preventative maintenance it needs (on the 95-96 gen2) is a new cap/rotor eventually
good luck !
i know it may not pertain to the 96 lt1 but i was telling her what it sounded like was going on to me.. they did have a 96 vortec engine also, when i get home from work i can punch in all the info on my ethos for a 96 lt1 and see if it gives me any "usual" known fixes for the problem
The LT1 has no such set up procedure. You can only install the distributor one way (unless you berak something) and what the OP needs to do now, is observe the performance of the distributor, while the car is acting up.
Ethos is a good tool. I have one too.
The early LT1's have the crank sensor and the cam sensor on the same "wheel", inside the distributor. All the info came from the dist. Later LTx's added a crank wheel for mis-fire detection. Still, those could only go together one way, so you still can't screw up the dist. installation. No special "lining up" needed.
The truck? IDK...I guess they had realized by that point that the optical wheel/sensor in the LTx was too susceptible to contamination and used a different system. It was probably cheaper too, since it used standard SBC items like that dist mount in the intake, standard timing chain/cover, block, cooling etc.
I'm kind of on board with the whole water pump leak issue - if the bearing fails (and they do) it will puke coolant out the hole and onto the optispark, but I'm confused as to how coolant is getting inside the unit. I've submurged these things as a test, then took them apart. They are sealed.
Then other people say "high voltage inside the unit takes out the optical sensor".. wtf ?
Then there are the theory's that only hitachi can make a good optical sensor. That's horse doodle. These are not complex devices.
I wonder if anyone has actually dissected a 'bad opti' with a scope and seen what exactly isn't working. What I have found to be suspect in these cars is the factory wiring. I've fixed more wiring problems on 4th gen fbody's and C4's than I can cound on all my fingers and toes. The grounds are always suspect as a start, but more than that wire corrosion within a few inches of the connectors. Strip back the wire on the IAC, TPS, ICM, etc and you'll find the conductors are corroded. Do a ohm test and they fail.
-- Joe
So in the OP's case, it sounds like the newer opti installed in her car does indeed have a failing sensor. Anesthes, the original sensors were Mitsubishi. I'm sure it's true that they aren't the only company that can make a decent optical sensor, but it does seem to be the case that most China-made replacements don't have good sensors for whatever reason. Supposedly the Petris and AIP replacement optis have better sensors in them. And Optidoc uses NOS or refurbished Mitsubishi sensors.
To the OP, if your car is running rough and missing, especially when it's still warming up, you're probably getting intermittent low-res signal. Whereas if it ran fine until warmed up and then just felt kind of low on power and "soggy," I would assume that hi-res signal is the main issue (note that you got codes for both signals). The fact that it's running at all tells me you must have at least one of the two signals at any given time. I would expect the tach to be acting crazy, like Tom mentioned, if the low-res signal is faulty. I'm afraid you're going to need to replace that opti again. If it were me, I'd insist on an AIP, Petris, or Optidoc unit. It seems like all the normal parts-store optis are just garbage.
