Stop lights doesn't work immediately when push pedal
Old May 1, 2019 | 04:45 PM
Christi@n's Avatar
Christi@n
Default Stop lights doesn't work immediately when push pedal
I've noticed on my 1995 that my brake lights doesn't immediately turn on when i push down brake pedal, I need to push a
little bit more than standard clearence would be on other car.
I think that a simply check on switch located behind the pedal would fix this problem, though is this check required or it's properly working at the moment?
Old May 1, 2019 | 06:15 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Sounds like the plunger in the switch might be hanging up. if you can take the switch out and clean it might clear up the problem.
Old May 2, 2019 | 02:18 PM
JoeNova's Avatar
JoeNova
The switch at the pedal is a threaded switch with a nut on the other side of the bracket.
You can adjust how close/far from the pedal it is. Sounds like it just needs adjusted.
Old May 5, 2019 | 06:18 AM
Christi@n's Avatar
Christi@n
Ok thank you guys
To Stop lights doesn't work immediately when push pedal
