What is the minimum oil pressure in an LT1 at idle? I've been messing with my oil system and it seems to be just fine when I push the gas but at idle it is a little low around the last tick mark on my oil gage before it goes into the hashed area.
That really is low! Won't the oil pressure switch turn the fuel pump off at 4 psi?
I don't think so, the red check gauge light comes on when it drops too low. taking a sharp turn when you are a quart or two low on oil will show you this. But there is no fuel shutoff.
The "g" just means "gauge". Or referenced to atmospheric pressure. It reads like you'd think it to read. Sorry for any confusion... we won't toss in absolute pressures to really screw things up :)
I would first verify the numbers. Install a direct pressure gauge, take some readings, cold, warm, idle, 2,000 rpm etc. Get the data points from a direct pressure gauge.
Then we have real numbers with little error for sending units, instrument error, etc.
