Irritating EGR CHECK ENGINE light!
Old May 2, 2019 | 11:14 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default Irritating EGR CHECK ENGINE light!
I have ALL new components installed in my EGR system now. But I've noticed that I still get that dreaded code #32 EGR system failure code and CHECK ENGINE light once in a while when I first start the cold engine. It will usually shut off after the engine is up to operating temperature. Or it will shut off when I turn the engine off and restart it. The engine runs perfectly though. What am I missing??
Old May 2, 2019 | 11:17 AM
vader86's Avatar
vader86
Its calling an EGR code immediately at startup? That should not happen.
EGR only functions at some throttle percentage (cannot remember the percentage) when the engine is over ~170F. You basically should be cruising at speed on the highway or a country road for it to activate in the first place.
Old May 2, 2019 | 11:18 AM
Whaleman's Avatar
Whaleman
I once had this happen. I had forgot to tighten the big hose clamp from the air cleaner to the MAF. Dan
Old May 2, 2019 | 11:24 AM
FOURSPEEDVETTE
Yes. It comes on immediately when starting the cold engine.
Old May 2, 2019 | 11:25 AM
FOURSPEEDVETTE
I'll give that a look. Thanks
Old May 2, 2019 | 11:29 AM
vader86's Avatar
vader86
Then either the SES is not a Code 32 or the EGR system is not the problem. It should not set until commanded on, and the computer looks for the voltage change, which sets the code.
Old May 2, 2019 | 11:32 AM
FOURSPEEDVETTE
I've run a code check every time it comes on. It's always a code #32.
Old May 2, 2019 | 04:25 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
You didn't state the year but here's what my 85 FSM says about this.
HTH
Joe K
To Irritating EGR CHECK ENGINE light!
