1995 vs 1996 ABS module
Old May 5, 2019 | 12:23 PM
lt4red's Avatar
lt4red
Default 1995 vs 1996 ABS module
I need a replacement and hoping someone can answer a question regarding the ABS/ASR module in my 1996. They are expensive even used on ebay and want to make sure if I get one off of a 1995 that it will still work on my 96?
The listings are saying they will interchange, but I can't find confirmation on that. Anyone have experience with this?
Old May 5, 2019 | 05:54 PM
hcbph's Avatar
hcbph
Look if there's a model number on each unit and if they match then it should be a slam dunk. If they don't then something is different between them or GM gave the same part a different model number which has happened before.
