Ostrich 2.0
Old May 12, 2019 | 01:51 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Default Ostrich 2.0
Will the Ostrich 2.0 work with my 1991 base, Auto, For tuning? Does it need any additional parts?
appreciate the feedback if anyone has experience with it.
TIA
Old May 12, 2019 | 06:42 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I have used it on my 90, You need the memcal adapter that connects to the ribbon cable and I had to use the short ribbon cable to get it to work, also none of the bins I got off the internet would work with the ostrich, The only bin that would work with the ostrich is the bin from my original memcal
Old May 12, 2019 | 06:58 AM
mlm0's Avatar
mlm0
I have used the ostrich for over two years on my 89 and love it. I had the longer ribbon cable but it was causing problems. I went back to standard length cable included with the kit, and everything is back to normal and working great
Old May 12, 2019 | 07:19 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Absolutely !!! TunerCat or TunerPro needed along with G1 adapter card. Get it with a 6" ribbon cable. Longer ribbon cables can cause issues.
Old May 12, 2019 | 03:54 PM
ZEROVETTE7's Avatar
ZEROVETTE7
Thanks all for the feedback I appreciate it.
It can be connected all the time right?
Doesn’t the ribbon and the connectors comes in the box as a package? From Moates?
TIA
Old May 12, 2019 | 04:11 PM
mlm0's Avatar
mlm0
In all comes in the package. You have to leave it connected all the time unless you burn a chip once you make all the changes you want. I just leave mine connected because I am learning and making changes as I learn
Old May 13, 2019 | 07:34 PM
eutu1984's Avatar
eutu1984
TIA
The ribbon cable that comes with it is to long and may cause problems on your 91, you want to also order the short 6 inche cable
Old May 13, 2019 | 08:15 PM
mlm0's Avatar
mlm0
To use the ostrich, you have to leave it connected ALL the time, because once you disconnect it, all the changes you made will go away. In simple terms, the ostrich takes the place of your mem cal in your computer ecu, which the car needs to operate. What you are really doing is piggy backing on your cars ome mem cal, by using a Moates g2 adapter.
I am using tuner pro rt with my ostrich. With the ostrich you can make changes as you are operating your car. This allows you to see how your car reacts to the changes real time. Once you are happy with your changes, you can drive your car with the ostrich plugged in, or you can save the changes to a tuner pro file and burn a chip to replace the ostrich in your ecu and plug it into your g2 adapter to replace the ostrich . I have been very basic with what you have to do, but there are a lot more things you can do with tuner pro. If you make changes, be sure you understand as best you can, what the changes will do or cause before you do them. The best thing is none of the changes are permanent. Just unplug the ostrich, the g2 adapter and re install your ome mem cal back in you ecu. Back to stock. There are people on this forum who know a lot more then I do about tuner pro or the ostrich, and I’m sure you will be able to get help. Be advise there is a learning curve to this process, so be prepared to spend some time on researching what you want to do. I have made changes to my fan temperature settings as to when I want them to come on and go off, idle rpm, egr delete, disabled vats, and tuned my air fuel settings at idle. I do not have a wide band 02 yet. Good luck
Mike
Old May 13, 2019 | 11:30 PM
ZEROVETTE7's Avatar
ZEROVETTE7
Thanks mlm0 very informative. I really appreciate all the info guys. Actually this time I won’t be doing the tune myself an expert will come with his laptop and softwares and I have to arrange for the hardwares and parts... I’ll be learning from him to do it myself in the future ...
so the shopping list is
-Ostrich 2.0
-6” ribbon (just Incase)
- G1 adapter card? (Is it required)
am I missing anything?
TIA
Old May 13, 2019 | 11:59 PM
mlm0's Avatar
mlm0
I said G2, but you are correct, G1. Maybe buy some chips to burn your program to. If you buy chips then you need burner. I bought burn2. It works great, but there are other options on Moates web site
is your programmer going to use your ostrich to tune your car? Is so, I would burn his final tune to a chip as well as save on a file in whatever program you use. Better to be safe, especially if you are paying for the tune. Be sure to read support files on Moates site to make sure you get what you need and that it is Correct
Old May 14, 2019 | 11:56 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Yes he requested I buy the hardware (the Ostrich 2.0) and he will do the tuning/programming...
It will be a learning session for me as I never did a tune/program before. That’s why I’m asking for the required parts (beside the Ostrich 2.0) I need to do it myself later in the future.
Updated shopping list:
-Ostrich 2.0
-6” ribbon
-Burn2
-GP1 kit (comes with GM adapter and 2 chips)
Old May 14, 2019 | 12:38 PM
mlm0's Avatar
mlm0
Looks like you are ready to go. You just need to decide on your tuning software To buy or download
good luck and let us know how it went
Mike
Old May 14, 2019 | 02:15 PM
ZEROVETTE7's Avatar
ZEROVETTE7
Mike
Sure thanks Mike, I guess I’ll go with tunerpro rt, but we’ll see ...
Old Jun 3, 2019 | 03:59 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Updates:
Just received the parts as shown in pics... (hope I didn’t miss anything)
And Quality looks awesome 👍🏻
So the guy will come probably next week for the programming and will be replacing some old wiring also while there... things I’m looking to program/tune
- Fans
- Egr delete
-Vats delete
- idle
Any other suggestions while there; since I’ll be installing headers and cat back system in the near future and maybe a First intake?
As mentioned before I’ll be learning from this guy about programming/tuning so as to be able to do that myself in the future (your advise and help will be needed then ).. can it be done using iPad Pro? Or only works with laptops and windows?
Old Jun 3, 2019 | 06:56 AM
mlm0's Avatar
mlm0
Looks like you have everything. I think it only works with windows but not positive
Old Jun 6, 2019 | 05:45 PM
scorp508's Avatar
scorp508
I'm unaware of any non-Windows options for programming that generation. I have the first generation Ostrich in my '87 and love it. Don't forget to save the file to disk somewhere safe if you plan to simply run the ostrich in the car all the time. Crack the Ostrich open every now and then to check the battery condition. I don't know what the current gen uses, but the 1st gen is a AAA battery. Mine got a bit crusty after a few years of the same battery being in it so I removed the battery, cleaned the terminals, and reprogrammed it.
Old Jun 6, 2019 | 06:42 PM
eutu1984's Avatar
eutu1984
I have never done it but I am pretty sure you can run the ostrich with ALDLDroid under android.
To Ostrich 2.0
