no codes and fan not going on
Old Nov 5, 2002 | 09:09 PM
atotalnincompoop's Avatar
atotalnincompoop
Default no codes and fan not going on
it doesn't even flash the code to let me know the system is operating, i think thats code 12, any ideas?
Old Nov 5, 2002 | 09:55 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: no codes and fan not going on (atotalnincompoop)
ECM? Bad ground on ECM?
Do you have HP numbers for your combo?
Pete
Old Nov 5, 2002 | 10:03 PM
atotalnincompoop
Default Re: no codes and fan not going on (PeteL)
where is the ground for the computer located?
[Modified by atotalnincompoop, 9:17 AM 11/6/2002]
Old Nov 6, 2002 | 04:22 PM
atotalnincompoop
does any one know the location of the computer ground? :confused: :cheers:
Old Nov 6, 2002 | 04:32 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
still trying think of what this could be....but yes...no code 12 is indicating a faulty computer....
i don't know where that ground is...but I would check all the connectors near the base of the computer....I think there is 3 main ones there......wiggle them back and forth...make sure they have not somehow gotten lose.....
jeff
Old Nov 6, 2002 | 04:50 PM
Togo's Avatar
Togo
Default Re: no codes and fan not going on (XtremeVette)
if it wasn't grounded, wouldn't that mean that the computer would not work at all, thus the car would not start at all (aren't the injectors controlled by the computer?)
Old Nov 6, 2002 | 06:45 PM
atotalnincompoop
i think its the computer, the guy in alberta who burnt my chip, is sending me another computer that is tested good to try. This guy is good, thanks all :cheers:
To no codes and fan not going on
