1991 Fuel pump upgrade
Old May 28, 2019 | 11:41 AM
littleredcorvette88's Avatar
littleredcorvette88
Default 1991 Fuel pump upgrade
Hi All,
I'm looking to upgrade my pump since I'll need more fuel for the holley efi I'm going to be running (58-60psi required). Holley gave me a few different part numbers that would work with the system but I'm not sure how that would connect to the gas cap filler plate attached to my current setup? They have an option for just the pump to install on the factory hanger as well to avoid this issue but I believe the lines on the factory hanger are to small (5/16") when they are saying I need 3/8" minimum. I plan on running new 3/8" line from the pump to the motor but not sure what to do about the hanger situation. Does anyone make aftermarket hangers with larger lines that also has the gas cap port built in?
Old May 28, 2019 | 01:47 PM
Kevova's Avatar
Kevova
Stock supply line should be 3/8. The return line is 5/16. Racetronix is a good choice for pump.
Old May 29, 2019 | 12:54 AM
aklim's Avatar
aklim
I second. Get the kit. Sure, it's boring to have all the parts to do the job without multiple trips to Autozone to finish it but such is life.
Old May 29, 2019 | 02:26 PM
littleredcorvette88
Racetronix pump only supports 43 psi and I have that kit installed now and it was great at the time! Just need to bbe pushing 60 psi for the new setup
Old May 29, 2019 | 03:08 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
This is dependant on the regulator setting, not the pump.
Our RXP pumps work just fine @ 60PSI.
Old May 29, 2019 | 03:40 PM
vader86's Avatar
vader86
Yes you are going to need adjustment to the regulator to get 60 and hold it, the Rx pump should be able to supply it easily.
To 1991 Fuel pump upgrade
