injector resistance
Old Jun 3, 2019 | 07:35 AM
jseremba's Avatar
jseremba
Default injector resistance
I purchased a set of injectors for 1985 Corvette. I tested the resistance. All 8 injectors are 12.4 -12.5 ohm. The resistance for the stock injectors is 14 - 16 ohm. Will the lower resistance cause any problems.
Thank you
Old Jun 3, 2019 | 08:17 AM
Joe C's Avatar
Joe C
Thank you
i'm thinking the coil resistance specs are between 12 and 17 ohms. if your injectors are within .1 ohms across the board, you have a nice balanced set. I wouldn't worry about anything.
Old Jun 3, 2019 | 02:37 PM
3D-Aircrew's Avatar
3D-Aircrew
Default should be fine
This would cause the injector coil current to be lower from ~.96 A to ~.75 A which is easier on the transistor drivers in the ECM so you shouldn't have any problems.
Old Jun 3, 2019 | 03:20 PM
aklim's Avatar
aklim
Probably not. Where did you get them from? If from a reputable source, no worries. Some eBay special, well....
Old Jun 3, 2019 | 06:46 PM
jseremba's Avatar
jseremba
Well they are rebuilt from ebay(Oh NO).
I did see someone on YouTube said that the balance is more important than the actual number. Just checking. People can say anything. This weekend the fuel pressure regulator goes. I turned on the car and the pressure is just below 40. but, drops almost immediately to 30 and ends up very close to 20 after a few minutes.
So new regulator.
thank s for the help
To injector resistance
