Manual Clutch Safety Switch
Old Jun 5, 2019 | 08:51 PM
rblakeney's Avatar
rblakeney
Default Manual Clutch Safety Switch
Car is an 89. I'm chasing a random no-crank symptom that does not reset after 4 or 5 minutes even when switching keys. Can take up to one hour.
  • Installed key cylinder resistor bypass at base of steering column.
  • New battery post bolts.
  • Preparing to bypass the starter enable relay.
When I push in the clutch, I clearly hear a relay clicking somewhere every time. Does this mean the clutch safety switch is working?
Old Jun 6, 2019 | 04:15 AM
FelixP's Avatar
FelixP
Not sure but my clutch safety switch is bypassed, maybe do the same to eliminate the issue?
Old Jun 6, 2019 | 08:25 AM
hcbph's Avatar
hcbph
That simply means something mechanical is moving and you can hear it. If you want to know if the physical switch is working. pull the connector, make up some jumpers with a battery powered light in it and plug it into the switch. If it goes on and off when you depress and release the clutch then the switch is likely good, if not then it's bad.
To bypass the switch, just make up a jumper that plugs in the connector that typically fits to the switch. That will act like the clutch is depressed so the car can start (all else working correctly). Remember though if you do this that the car can be started in gear now so be careful.
Old Jun 6, 2019 | 11:23 AM
rblakeney's Avatar
rblakeney
Thanks, guys. I will attempt to get my fat butt under there and take a look. New switches are available but I understand that it is not an easy swap.
Old Nov 12, 2019 | 07:31 PM
rblakeney's Avatar
rblakeney
For anyone that may be watching this, it turned out to be the starter bendix. New (rebuilt) starter and I am golden.
Old Nov 12, 2019 | 08:16 PM
hcbph's Avatar
hcbph
good to hear you are fixed up and running again.
To Manual Clutch Safety Switch
