light knocking sound coming from engine?
1. Ignore the knock like i have the past 2-3 years, and wait until i have more money for rebuild
2. Or, should i pull the oil pan and change the bearings and hope thats the problem.
I need to know if i opt for the second choice, would changing the bearings alone be dangerous, and do you guys think it would fix the problem.
I think i am capable of rebuilding the motor in my car. I helped rebuild motor in my old 89 toyota p/u, I have several friends who are engine savvy. What would you guys do with a budget of about $700? Any input would be great.. Keep in mind this is my daily driver.. I could take off work for a week if necessary (paid vacation time) :jester
Thanx and sorry for long jumbled thread..
Believe it or not, but im actually writing a report on flexible benefit plans in small companies. Im tired of being all gramatically correct and stuff :p:
[Modified by quiksilver458, 9:29 PM 11/6/2002]
For me, I would like to atleast find out which cylinder is the offending party. This can be a pain but you could use an automotive stethescope. Or, pull one plug wire at a time and note any change. When pulling the wire on the offending cylinder, you MAY note a significant change in tone. With no spark, the cylinder is along for a ride and no combustion stressing components. With that, any dropping the pan would allow a quick check of one or two journals. Of course, long as the pan is down, might as well do all.
Another diagnostic aid MAY be a cylinder leak down check. This MAY help determine if some ring lands have decided to collapse around the ring and give some "piston slap" which is also tough to nail down. Anything from the piston/rod area can give a characteristic deep knock. There are some enigne guys with really good ears. Not me. A knock's a knock. Hate em all.
SPECULATION HERE- With good oil pressure verified, supsect the bottom end could be ok. Bottom end knocks tend to get worse with corresponding drops in oil pressure. Though not always. General comments here.
Couple of quick questions. Is the knock consistent across temperature range, from start up(cold), to warm up, operating temperature, fairly consistent. Or, as the car warms up, the knock decreases slightly?
Does the knock vary a little bit when you use say straight 20 wt, 30 wt or 20-40 wt oil?
Anyway, also like to hear from others. Tough call.
dlmeyers 90 coupe zf6 3 speed shocks
I was using a 10-40 oil for a while, an then my mechanic, (which i never visit anymore) told me to switch over to a heavier weight to help with the wear. Now im using the valvoline race oil.. a straight 50 weight. This is what he advised about a year ago.. The only thing i have noticed is that my car heats up to operating temp a lil faster. This im sure is because of how think the oil is. Thanks for the advise dlmeyers. I plan on doing firing up the car, and pulling spark plub wires to see if i hear a difference in the sound.. Also, If i, or you guys determine i should say drop the pan and just pull and replace the bearings, will that affect me in a bad way? I just assume let the car keep going since it seems to drive and perform just fine. I just dont want to run the risk of throwing a rod or something.. Thanx :jester
[Modified by quiksilver458, 12:14 PM 11/7/2002]
I have a 92 LT1 with the same problem you just described so I am interested in hearing if you find out what it is. Mine drives me CRAZY! It has been ticking for 2 years ever since I bought it. I have taken it to two different mechanics and one tightened the lifters and the other replaced the rods. It still ticks.
It doesn't seem to affect the performance though but I'm afraid it will affect resale.
Good luck with it. :cheers:
