please help with air cleaner
Old Jun 13, 2019 | 09:00 PM
bdake8230's Avatar
bdake8230
Navigator
Default please help with air cleaner
Hello, im in a bit on a conundrum here. i have an 84 and recently removed the splatter fire and put a whole new trick flow top end, edelbrock torker 2 intake and holley sniper system on the car, for those of you carb swap guys. what did you use for an air cleaner. this is an automatic car also so throttle bracket also has the tv cable on it. i tried one of the edelbrock like triangle shaped cleaners and that did not clear. any an all help on this would be great. i dont want to run this without a air cleaner to test an tune it. i also need to retain factory hood...
Last edited by bdake8230; Jun 13, 2019 at 09:01 PM. Reason: forgot to mention wanting to retain factory hood
Old Jun 13, 2019 | 10:20 PM
Kevova's Avatar
Kevova
Can you close hood without air filter? Moroso made a low profile air cleaner years ago. Your choice in intake is on the tall side for any Corvette with a flat hood. You may need to look for a Weiand low rise manifold.
Old Jun 13, 2019 | 11:06 PM
bdake8230's Avatar
bdake8230
Navigator
Originally Posted by Kevova
Can you close hood without air filter? Moroso made a low profile air cleaner years ago. Your choice in intake is on the tall side for any Corvette with a flat hood. You may need to look for a Weisnd low rise manifold.
Yes I can close hood, the Edelbrock cleaner almost cleared. I just wonder with the sniper linkage what I need or do all drop base clear the linkages
Old Jun 14, 2019 | 07:32 AM
Kevova's Avatar
Kevova
No, some are about the same as a stock carb air filter. Air filter elements height vary if may take some trial and error. TV bracket - shopping at "pick n pull" yard might net several different factory brackets to try.
To please help with air cleaner
