‘94 LT1 cheap preformance mods?
I know of one guy who does tuning as a side job when time permits. So how long did it take you to get to pro level, assuming you are at pro level?
I'm no expert in engine tuning. My expertise is in telecommunications electronics, but you don't need an electronics background to use these tools, learn about your car and edit the PCM programming.
This is not a job that needs to be done daily, weekly or even monthly. Unless you make enough mods, you could probably set it and forget it. Say you spend 40 hours learning how to do the tweaks, how much more time to learn till you are as good as the pro? As I said, it cost me $600 for a dyno tune. How many hours of your time would that buy till you feel you can do as good a job as they did. Say you are worth $25 an hour. Think you are as good as the shop after leaning it for 24 hours? Think after 24 hours of leaning time you are ready to go pro?
Data logging will show where the PCM is adding or subtracting fuel to maintain stoichiometric combustion. That feedback covers part-throttle operation very well. WOT operation is a bit more work as you really do want a wideband O2 to accurately hit a target A/F outside of lambda and it's not as easy to hit the target the first time through.
The MAF equipped cars like mine and the original poster's sense how much air is being consumed and the PCM injects the correct proportion of fuel in response. This makes the MAF cars easier to tune and less in need of retuning. Longer duration cam? That's going to throw off MAP sensor readings as vacuum went down at low engine speeds, but the MAF measures the actual air flow rather than looking up what it should be in the VE tables for a given RPM and MAP value.
You really are invested in this idea of being a pro and in defending having spent $600 to tune your car. I'm investing in knowing more about my car and being self sufficient. I am not investing any more time in explaining myself.
I hope that I have dispelled any notion that I don't know the whys and where-fores of the systems I'm interacting with. Now, back to the point...
My point was that a MAF equipped system is much more flexible than a speed density system. Different companies have used different strategies at different times. We can see that GM changed strategies in 1994 and that is an advantage for the late C4s. Ford used MAF sensors a lot as a given engine combination didn't have to be retuned for every little chassis variation. But MAF sensors are more expensive than MAP sensors so if you can amortize the tuning cost of each chassis across enough units it saves money. Never fail to account for cost savings when assessing why something was done a particular way. Nor can market demands or government mandates be ignored.
You didn't. I didn't question if you knew the system. I will tell you that knowing the parts and components does not yield the ability to tune properly and certainly not expertly.
Yes they serve this function, but there is also more the computer uses them for to make decisions.
Lots of other cars didn't. And while it does help with emissions, there is also something about economy and proper operation. Do not look past the feedback system helping with emissions also extending the life of other parts of the engine by providing a clean burn. Also, the feedback loop helps dial in proper fueling for clean burn, economy, and safely making power. Sure beats listening to the engine, looking at exhaust and reading spark plugs. All though, I don't suggest abandoning those as tools in your tool box either unless you have the ability to get feedback from each cylinder individually.
The ability to operate doesn't mean it’s optimized. That car made all of 130hp with leaded fuel and no emissions. It was only an 8.5:1 Compression ratio engine leaving a lot of room for error in timing and fueling. Pales in comparison to today's engine abilities, while meeting emissions. No to mention it only got around 22mpg. Not exactly a "Worlds Best" bench mark to set.
Again, the ability to operate in open loop doesn't mean it is optimized. In 2000, Honda updated the fifth-generation VFR (RC46) with a catalytic converter, oxygen sensors, and an EFI system that would enter closed-loop mode under highway (cruising) operation. You will have to address both open and closed loop in your system. Obviously there was a need, because on 15 January 2004, EPA’s Control Of Emissions From Highway Motorcycles Rule (69 FR 2398)established 2 tiers of conventional pollutant exhaust emissions standards for highway motorcycles in the United States. Tier 1 came into effect in 2006, and remains in effect for Class I and II motorcycles.
I am not saying you shouldn't start playing with the tune in your car. I am thinking about doing some playing with tuning as well. Especially to be able to turn a few things off. I do think you are setting yourself up for disaster being over confident in your knowledge and anticipated results. I would suggest keeping the original file so you can always go back. When I start playing with my IROC’s tune, I am going to get a complete new chip and keep my current bin on a chip ready to go. I know the components, I know what they read and how they function. I know what the ECM is supposed to do with them, but how it uses all the tables together… I feel I know very little and will approach accordingly. If you don’t humble yourself now, the process will later.
All true. What's also true is that the forums are necessarily limiting in scope and I further limit myself on how much time I'm willing to devote to these discussions.
We have a history of Otto engine fueling from surface carburetors, float and pressure carburetors, a huge variety of mechanical injection methods, moving into analog computer-controlled solenoid fuel injection, some mechanical injection added back in which later added electronic feedback, feedback carburetors, and digital computer-controlled injection. All the electronic systems have used with increasingly advanced sensors, controls, processors and memory. More recently we have electronic direct injection, dual injection and on the fringe, HCCI. The history is important. As we are in the C4 Tech/Performance what's most relevant is digital EFI with 2 to 8 (+1 for early TPI) injectors, the various control strategies and the hardware required to implement them. Not once have I held myself out as a tuning expert. In fact, if you go back you'll see where I state what I've learned about my '94 as a novice using cheap hardware and free software. I have yet to make one edit to the PCM.
