Oil temp sender/Gauge
Old Jun 14, 2019 | 08:14 PM
BLKMAMBA's Avatar
BLKMAMBA
Default Oil temp sender/Gauge
Hi all quick question, during my long tube header install I apparently broke the oil temp sender in my 93 LT1 car. I bought what I was told a NOS sender from a member on here. I recently installed it and my oil temp gauge still does not work. it worked fine before header install. and can not verify temp through LED on dash because I have the issue that the LED does not work, most of the time. I bought the plug from Batee(another story) anyway can I get some help troubleshooting why it no longer works. I am not sure what else is part of that gauge. thank you
Actually after blowing up this picture I noticed I may have found my problem. I need to get under there again and check them wires
