Spark Plugs
The only way I know to get more power from a spark plug is to run a lower resistance plug and wires so it uses less energy to get to the tip of the plug allowing for a bigger initial spark. This can be done in conjunction with a higher powered ignition and allow for a wider gap. Again... all about getting a bigger spark. Also in boosted applications, the extra energy helps because air has an extremely high resistance and poor conductivity. So, jumping the gap reliably can require more energy at the tip.
All this said, there is another item not looked at. That is where the electrode orients itself in relation to the piston and where the air/fuel charge settles in the combustion chamber. This ofcourse is on a very "atomic" scale because there is enough fuel in the mixture to ignite regardless of electrode position. Though, if you are trying to squeeze every last 1/4hp out and have the money, you can buy 50 plugs and index them once installed and run a matched set of 8. Some race teams do this.
All in all, the spark plugs can't do much to increase air flow or add additional fuel. So they can't add more energy to the thermodynamic equation that governs the reaction in an IC engine. All they can do is help ensure all the air/fuel mixture is ignited fully earlier.
So, with Platinum having a higher resistance than Copper... what real world improvements do you expect to see from spark plugs?
Conventional copper plugs may result in a slightly stronger spark but not enough to actually increase performance -- either the fuel charge is being ignited, or it is not. That's why many knowledgeable people call BS on the splitfire and E3 "performance" plugs. Everything else being equal, the only way a plug can be better than another is in how long it lasts in the engine (iridium/platinum).
Physics and electrons. Things that matter care about conductivity and resistance. You wiring harness sure does too.
Good luck with that from spark plugs. In short - the difference is so small you should never notice. Any wild claims from a spark plug company about added performance is snake oil. Engines convert energy from gasoline into rotational energy. Thermodynamic law states energy cannot be created or destroyed, only converted. A spark plug injects energy in the form of a spark for a millisecond. It cannot add additional energy to the combustion process beyond that.
These are not opinions, it is science. If there was an actual spark plug that could increase power significantly, they would be all over the magazines and everyone would use them in their builds. Everyone has a preference and that is fine. There isn't enough difference from one plug to another to significantly change the end result.
