A/C not blowing
Old Jun 18, 2019 | 01:32 PM
CarLover014's Avatar
CarLover014
Default A/C not blowing
I just bought a 96 Corvette as my first project car. Since everything mechanically except for some emissions equipment works perfectly, I wanted to start by fixing the A/C. 95% of the time it does not blow anything, and 5% it works decently. I do not have the optional climate control system. The only time anything blows through the vents if if I have it set to vent. Any ideas what would be causing this?
Old Jun 23, 2019 | 08:52 AM
pbellone's Avatar
pbellone
Get a FSM and use the trouble shooting tables to track it down. I have a C68 option and it helps to use the testing flow charts to narrow down the issues.
Old Jun 23, 2019 | 09:27 AM
Kevova's Avatar
Kevova
Is your problem blower has no speeds or only operates when vent button is pressed.
Old Jun 23, 2019 | 10:35 AM
CarLover014
Vent always works. But if I have it on a different setting, most of the time, nothing blows out the vents. Very rarely does it actually run on other settings. I think it might be a bad connector
Old Jun 23, 2019 | 10:38 AM
Kevova's Avatar
Kevova
Sounds like you need to check control.
Old Jun 23, 2019 | 07:41 PM
aklim's Avatar
aklim
So are you saying that you hear the fan blowing but nothing comes out of the vents. If so it may be coming out of the defrost.
Old Jun 23, 2019 | 08:51 PM
CarLover014
It isn't that either. I've been told by a retired GM mechanic in the area that I might just be low on Freon.
Old Jun 23, 2019 | 09:55 PM
aklim's Avatar
aklim
It might be but if the fan isn't blowing at all, I don't know how Freon will help the fan blow.
To A/C not blowing
