C68 - Auto Climate Control - Troubleshooting
Here's what I've got so far.
- When I got it the compressor clutch wouldn't engage - period.
- The blower fan worked on auto and I had manual speed control.
- The controller buttons were blinking denoting problems and reactions to pushing the buttons was unpredictable.
- I had low refrigerant denoted by code 09 in the control module and a gauge connected to the system confirmed that.
Since we were working in the dark we called it quits. Tomorrow I'll disconnect the battery, wait 5 minutes, reconnect it and see what happens. Not sure if disconnecting the battery will clear the 09 code in the A/C controller modules or if I'll have to do that separately.
It appears that whatever tells the system to actuate the compressor clutch relay ISN'T. If I get lucky disconnecting the battery will reset everything and I'll be good to go but I'm not holding my breath.
If anyone wants to comment feel free, I'm flying blind here with no manuals, looking forward to getting my hands on them.
Of course I discovered other things that I need to fix; I either have a fuel delivery or ignition problem that becomes apparent under certain conditions, some of the functions on the Bose radio aren't working, ex. scan and search (added to the CD which doesn't work), the rear hatch release button in the console doesn't work, under heavy braking I get a pulsation, I have a balance issue at about 77 to 80 mph (likely due to the damaged right front rim).
Bought new rotors for front and they went away!
Congrats on the A/C fix!
I bought a nice set of four slotted/drilled rotors for my C4 at Rockauto and they were less than $400 for the set. I just installed slotted/drilled Rotors on my daughters 2011 Camaro and what a difference it makes with a good set of ceramic pads.
If you have any questions about the C68 get in touch with BATEE.COM as he helped me by fixing my C68 when it was acting all wonky. He can fix it for you or he will sell you the parts to fix it yourself, either way it is fast and affordable.
Best Regards,
Chris
Best Regards,
Chris
I found Batee.com and was thinking about whether it was better to try to fix the control module myself or sent it to him. Certainly much easier to send it to someone who knows it 'cold'.
The discussion I find interesting is the one about whether or not to take off the top, open the doors, pop the hatch and open the hood before jacking.
These cars are seriously solid. You can raise the entire side of the car if you put the jack in the middle.
Pinch welds are your friend.
Edited to add:
Hmmm, guess I'm still learning about this forum, I didn't think I hit multi quote but there it is. Of course I'm old, maybe I'm just confused?
This had an original date of 2004: How to jack up a ZR-1
