Power steering fluid filter
Old Nov 7, 2002 | 02:01 PM
Tom Piper's Avatar
Tom Piper
Default Power steering fluid filter
I've thought about this for some time -- I decided to install a filter in the return line for the power steering fluid.
After losing the power steering pumps and gearboxes in my Lincoln Town Car and my Ford truck, I made up my mind to put a filter in all three. I decided to do the '92 Corvette first -- I just finished it and it works like a charm. Hopefully, this will mean I won't have to change the Vette pump and steering rack.
Tom Piper
[Modified by Tom Piper, 6:28 PM 11/7/2002]
Old Nov 7, 2002 | 02:03 PM
Togo's Avatar
Togo
Default Re: Power steering fluid filter (Tom Piper)
After loosing the power steering pumps and gearboxes in my Lincoln Town Car and my Ford truck, I made up my mind to put a filter in all three. I decided to do the '92 Corvette first -- I just finished it and it works like a charm. Hopefully, this will mean I won't have to change the Vette pump and steering rack.
Tom Piper
:confused: pics?
Old Nov 7, 2002 | 04:04 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
PICs!!!!!!!!???????????????
Old Nov 7, 2002 | 05:00 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Power steering fluid filter (85_togo)
I would also like to see your setup. Sounds like a good idea for all cars.
J :seeya
Old Nov 7, 2002 | 05:19 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Power steering fluid filter (JCAIRE2)
J :seeya
I'd like to see this as well. Pics and the tech info please.
Old Nov 7, 2002 | 05:32 PM
Tom Piper's Avatar
Tom Piper
Default Re: Power steering fluid filter (Bluewasp)
The last camera I had got sand in it at the beach. I never bought another one. I should get a digital camera.....just haven't gotten around to it.
The filter I used is an ATP in-line-transmission filter part # JX-160 (see below). It is designed for the automatic transmission or power steering fluid. I'm told WIX also makes one. The fluid in the power steering is similar to the fluid used in an automatic transmission.
ATP -inc.
Morton Grove, Illinois
Tom Piper
Old Nov 7, 2002 | 05:39 PM
Caboboy's Avatar
Caboboy
Don't be teasin' us like this...... go out and buy a camera!!!! :lol: :lol: :lol:
Old Nov 7, 2002 | 06:54 PM
Reno67's Avatar
Reno67
Excellent idea. If it looks good, I may have to do the say.
Old Nov 8, 2002 | 06:31 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Excuse me.....was that a Lincoln Town Car.......??????????????
:jester :jester :jester :jester
Old Nov 8, 2002 | 06:48 PM
c4md's Avatar
c4md
Default Re: Power steering fluid filter (oldace84)
Hey, I had an 84 Caddy Fleetwood. Great car for trips! It blew up and I miss it.
Old Nov 8, 2002 | 07:44 PM
BBA's Avatar
BBA
You better plan on replacing it every three or four months or you will be replacing the pump after the filter cloggs and causes the pump to burn up.
In otherwords, putting a filter in line with the PS hoses is the best way to burn up a PS pump.
Don't do it unless you enjoy working on your car...a lot. :crazy:
Old Nov 8, 2002 | 07:46 PM
BBA's Avatar
BBA
Default Re: Power steering fluid filter (BBA)
BTW: I've made quite a bit of money rebuilding dead transmissions people put those filters on and forgot to change them.
Be warned!
[Modified by BBA, 6:47 PM 11/8/2002]
Old Nov 8, 2002 | 09:31 PM
Tom Piper's Avatar
Tom Piper
Thanks for the warning.
In the case of the Corvette, it's just used for pleasure driving :jester . So, I imagine I won't have to change it often.
But, for my truck and Lincoln, you may have a good point -- I will make a point to change the filter often.
Tom Piper
Old Nov 8, 2002 | 09:39 PM
ybodycrh's Avatar
ybodycrh
3rd Gear
:nono:
Old Nov 8, 2002 | 11:19 PM
bill mcdonald's Avatar
bill mcdonald
I have a powersteering filter as well.
I picked mine up from guildstrand for 16 bucks or what ever.
I have had it in there for 20K miles and had no problems. I replaced the rack and the power steering pump at the same time.
Old Nov 9, 2002 | 09:23 AM
Tom Piper's Avatar
Tom Piper
Be warned!
Since reading this, I have done some research on the subject.
I don't know how installing a in-line-filter in the transmission might be harmful; but, from my research, it appears that installing a filter in the return line of the power steering is not harmful. In fact, if the sites I have read are correct, certain BMW vehicles come with a power steering filter. So, do many motor homes, tractors, etc.
Here are some sites: http://www.bareco.com.au/files/ford2001/frd16.htm http://www.italtec.it/en-1076.htm
Here is some text from this site: http://www.babcox.com/editorial/ic/ic129940.htm
"When hoses are replaced, the system should always be flushed to remove all traces of debris. Flushing should also be done when replacing a pump or rack so debris in the old fluid can’t damage the new parts. Installing an in-line filter isn’t a bad idea to protect the longevity of the new components."
Actually, almost all power steering pumps have a screen filter in them -- if that screen gets plugged, you have to rebulld or replace the pump.
In addition, the intructions that come with the Atesco and A1Cardon rebuilt pumps actually suggest installing an in-line-filter to protect the pump.
Tom Piper
Old Nov 9, 2002 | 12:05 PM
Rick93Z07's Avatar
Rick93Z07
Tom,
Where did you install the in-line filter, in the return line just below the reservoir?
Old Nov 14, 2002 | 12:55 PM
Tom Piper's Avatar
Tom Piper
Default Re: Power steering fluid filter (Rick93Z07)
Tom,
That is correct.
By the way, I found the instruction sheet for the rebuilt A1Cardon steering gear for my Lincoln. It states that the "warranty is void if an in-line filter is not installed."
Tom Piper
Old Nov 14, 2002 | 02:38 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Sounds like a great idea.
This should be in C4 tech recommendations. I imagine the filter and fluid should be flushed every two years. A good flush procedure is in order too.
I had to drain the fluid in my system when I pulled the motor. I noticed a lot of stuff in the fluid at that time. I used new fluid and put the motor back in. I had to pull the engine a second time right after that. I still saw quite a bit of stuff. I recently had to (you guessed it) pull the engine again but didn't see any fluid.
To Power steering fluid filter
