Dana 36 remove and replace procedure
Old Jun 24, 2019 | 03:56 PM
garyc4's Avatar
garyc4
Default Dana 36 remove and replace procedure
Hello, planning to R&R my Dana 36 with a higher ratio. Looking for opinion/experience with how best to do that. Specifically, should I plan on differential and batwing removal, and then swap out differentials on the bench, or can I remove just the differential unit on the car without removal of other major components (except the driveshaft of course).
Now, I know and understand all the 36 vs 44 discussion out there, and I’m considering my options, but if you can provide any helpful info on my question it would be much appreciated. Thanks!
Old Jun 24, 2019 | 05:10 PM
vette196's Avatar
vette196
I don't think you'll need to remove the batwing.
Old Jun 25, 2019 | 09:23 AM
fredk's Avatar
fredk
I would pay a shop to change gears. Lot's involved for a home mechanic.
Old Jun 25, 2019 | 09:54 AM
ghoastrider1's Avatar
ghoastrider1
might cost a bit for tools to do it right at home. I have a rscer friend that builds rearend pumpkins and wants 100 bucks to swap out gears on mine. A price I will gladly pay. Best of luck.
Old Jun 25, 2019 | 11:01 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
My son was charged almost $400 to swap gears and get them setup correctly due to the time it took to shim them in to the correct contact pattern. By the time you buy the gears, buy new seals (and probably bearings) and pay someone to put them in, you will have most of the cost of a Dana 44 swap covered.
Old Jun 25, 2019 | 12:02 PM
vette196's Avatar
vette196
can he do mine?
Old Jun 25, 2019 | 01:59 PM
Randy M's Avatar
Randy M
I personally found it easiest to remove the carrier and differential as an assembly and then swap the differential. It is only a couple of bolts at that point as you have removed everything else in the way already. All the gasket cleaning and remounting of the differential is a lot easier on a bench in my opinion.
Old Jun 25, 2019 | 02:56 PM
A95Y's Avatar
A95Y
I never took one out any other way. I liked the 3.73's I had in my 36. I have 4.10's in my 44, might have liked 3.73.s.
To Dana 36 remove and replace procedure
