Third gear sticks................
Old Nov 7, 2002 | 03:46 PM
Alphatoto's Avatar
Alphatoto
Default Third gear sticks................
Especially when cold but can happen anytime. It feels like the gate is blocked. Any ideas?
Also, took the car to the track last night for the first time and I was so nervous about being locked out of third I accidently threw into 5th. This caused the clucth to slip and burn, smelled bad for two days...........
Bad synchro, maybe?
Old Nov 7, 2002 | 11:37 PM
bogus's Avatar
bogus
Default Re: Third gear sticks................ (Alphatoto)
ok... 2 questions...
1. has the trans fluid ever been change?
2. do you have CAGS overridden?
***EDIT*** disregard #2... :)
I didn't realize you had a 6spd conversion.
a new #2 takes its place :D
2. What year is the 6spd???
I cannot beleive that going into 5th my mistake will hurt anything.
[Modified by bogus, 10:40 PM 11/7/2002]
Old Nov 8, 2002 | 11:21 AM
Alphatoto's Avatar
Alphatoto
Default Re: Third gear sticks................ (bogus)
I suspect the trans fluid was changed when the motor was rebuilt 25k miles ago (by previous owner) but I cant be sure. They did a a real good job on the rebuild so I would think they canged the trans fluid when they dropped in the 6 speed.
It came from a '91.
Old Nov 8, 2002 | 04:42 PM
bogus's Avatar
bogus
I would make sure the trans fluid is up and clean.
cheap insurance.
the 91's are the best of the ZFs... they continually "improved" them to make them quieter, etc.
I would be surprised if you hurt that tranny...
check back tonite... I have a web site that will be able to help, but I am at work.
[Modified by bogus, 3:47 PM 11/8/2002]
Old Nov 8, 2002 | 06:01 PM
vetracer's Avatar
vetracer
My '86 coupe has a '94 ZF six speed conversion and does this too... except mine does it in third and fifth. It doesn't do it often enough that I see a need to pull the tranny, though. Mine has new GM MT fluid as well, I don't think that is the problem. I think the clutch can be ruled out too, as it is definitely limited to a particular gear. :confused:
To Third gear sticks................
