Dielectric Grease Article
Old Jul 5, 2019 | 08:32 PM
rusty76's Avatar
rusty76
Default Dielectric Grease Article
Someone posted this link on another forum I frequent. Given the dependence on electrical connections we have in the fuel injected Corvette world I thought it might have value to post the link here. I hope I'm not breaking any rules here. I guess if I am someone will rip me a new one - sounds exciting!
https://www.w8ji.com/dielectric_grea...ive_grease.htm
Old Jul 6, 2019 | 09:53 AM
MatthewMiller's Avatar
MatthewMiller
That's a very interesting article. In addition to the info about electrical connections, the info on the thermal applications in heat sinks is also applicable to most of our C4s: think about ignition modules. Thanks for posting this!
Old Jul 6, 2019 | 01:10 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
thnx for posting rusty.
ive always been under the impression that any grease keeps the moistire and contaminents out of an electrical connection.
i recall looking at the bottom of my icm and seeing grease likely to conduct heat. its nice to see that silicon grease and thermal paste if applied similarly (thin wipe) are virtually the same for heat conductivity.
thanks again.
Old Jul 6, 2019 | 02:36 PM
SJW's Avatar
SJW
Great info. Thanks for posting this!
Live well,
SJW
Old Jul 6, 2019 | 02:54 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Thx for the article. But I what I read in it is contrary to what I have seen used in some applications. The Austrian/German made Rotax motors (CanAm 3 wheelers among other applications) use a silicone based heat conductive grease on the spark plugs ($150 for 4oz tube) so I'm not convinced of that articles testing methods.
That and I need more time to read the whole article.
I do see a lot of mis-uses for the dielectric grease as many imply application on the conductors where it shouldn't be but it's real help is on the boots of plug wires. Now there are greases used on some conductors like firewall connectors that I haven't been able to identify myself but you know they have to be non-conductive there while preventing arching and contact corrosion. The grease I have seen there is a mucky brown that's not on any parts store shelf that I can find.
I think this thread is just beginning.
Old Jul 7, 2019 | 11:07 AM
VikingTrad3r
Oil Producer
cardo didnt the posted link say it was infact useful to transmit heat? very close to “thermal paste” if applied thinly. perhaps why the tube was so small and expensive.
Old Jul 7, 2019 | 11:12 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old Jul 8, 2019 | 12:25 AM
cardo0's Avatar
cardo0
Default measured the resistance just for fun
So I took the time to read the full article just once and it reads like the clear silicone dielectric grease is the best all around heat conductive and non-conductive coating to prevent corrosion. I like how he says beware of using anti-seize on spark plugs because it will cause the insulator to fail if contaminated while it is helpful on the threads of the spark plug. That's something very good to know.
So I wanted to ad some pix of measuring the resistance my new jar of heat conductive grease which looks to have the undesirable power metal in it. I think I need to make several separate posts to display the measuring process. So to start with I measured my lead resistance and then my body resistance from hand to hand. I don't think my "free with purchase" Harbor Freight meter was accurate as normally my body resistance is less than 100 ohms but today is was 1.3 mega ohms. Just couldn't find my better meter.
meter lead resistance less than 1 ohm
my body resistance from hand to hand = 1.3 mega ohm
Old Jul 8, 2019 | 12:30 AM
cardo0's Avatar
cardo0
Default more measurements
And now here is the dielectric grease label and resistance measurement.
heat conductive grease container label
heat conductive grease resistance greater than 2 mega ohm
Finally just for fun I measure resistance on some petroleum jelly.
petroleum jelly resistance greater than 2 mega ohm
To Dielectric Grease Article
