1987 Corvette L98 turns over fires but won’t start
I have a 1987 z-51 corvette with a stock L98 and sometimes it will start and run just fine sometimes it will turn over fire and then die I am out of ideas on what it could be causing it I plan on driving it to college next month and I’d like for it to be more reliable I have replaced the following, MAF, TPS IAC fuel pump fuel filter oil pressure switch I’ve disabled the VATS it has all new plugs and wires I’m tired of spending money on parts that don’t fix my problem my next route would be either new injectors or Ecu any advice would be much appreciated
start with the basics - FUEL, spark , timing. have you run a fuel pressure test? do you have a FSM? BTW, quit throwing parts at the problem.
When it won't start, check your fuel pressure at the rail. Could be a Fuel pressure regulator.
Sounds like a Fuel Problem. When it wont start, spray some starting fluid in the throttle body to confirm. If it starts, it's probably not a timing or ignition related problem. Diagnose, don't guess.
Received 1,401 Likes
Sounds like fuel-issues. Check fuel pressure at rail first, with ignition in run but not started, then see how it behaves when you try to fire it.
Hook up pressure gauge at rail, observe pressure when running. Turn off car or let it turn off by itself, watch FP gauge reading. Should hold.
Then best to hook up a scanner and datalog it to see what the computer is seeing before replacing any further parts.
Do parts stores scan OBD1 anymore?
Parts stores scan codes, what you want to do is buy a scanner that will read OBD1. Mine is an Actron from Autozone with an adapter to let it read OBD1.
You can also buy an OBD1 cable and use DataMaster on your laptop.
Okay I’ll pick one up is there a link to download data master? Or is it just a website?
Then what is the code set?
If your O2 sensor is dead or dying it can flood the engine and make it cut off.
Replace the sensor and check its wiring, that should've been the first thing you did.
