Where is EST disconnect located
Old Nov 8, 2002 | 11:23 AM
Five Window's Avatar
Five Window
Default Where is EST disconnect located
Late '86 convert. Aluminum heads
In setting initial timing, the shop manual calls for the disconnection of the EST wire. It is one of those going to the four wire connector at the distrib.
It's supposed to have its own connector somewhere between the distrib connector and the harness. Can't find it.
Also, any feedback on MSD stock replacement injectors would be appreciated. Are the stock GM ones 22lbs/hr?
Thanks :confused:
Old Nov 8, 2002 | 11:59 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Where is EST disconnect located (Five Window)
It's a single wire connection brown wire between the brake booster and the engine.
Old Nov 8, 2002 | 12:30 PM
Five Window
Default Re: Where is EST disconnect located (War Machine)
THANKS
To Where is EST disconnect located
