Re: Head Gasket Thickness = ? (TrueBlue ChevyDude)
That's what I was afraid of.
I have Dart Iron Eagle heads with 64cc chambers. The pistons are hypereutectic flat tops that probably have valve reliefs (cc=?). Assuming that the top of the pistons are flush with the deck at TDC and the .039 gasket thickness my static compression ratio is 11.8:1! Yikes!
I'm hearing some detonation at WOT in 3rd gear with 93 octane. Now I know why. Base timing is 7 degrees.
Bought this longblock from Speed-O-Motive. They said the comp ratio was 10.5:1. Guess I shoulda checked their math.
Anybody got some aluminum 72cc chamber heads they wanna sell?
Dug up the invoice for my long block and made some calls. First of all my pistons are .060" over so the engine is technically a 388. The valve reliefs in these pistons, Silv-O-Lite H3426-060 hypereutectics, add 5cc of volume to the chamber. I also found that my head gaskets are in fact .039" thick and the gasket bores are actually 4.166".
Taking all that into account gives 11.2:1 compression which is still too high to run pump gas with iron heads. All the "experts" I've talked say that if these were aluminum heads I'd be okay. I think I'll still swap to 72cc chambers anyway if I get some new heads. That knocks it down to 10.3:1. I'm not willing to bump up the camshaft duration either. If anything I'd like to go with less duration (220/220 vs 224/230) and widen the LSA to 112 from 110.
I put 5 gallons of 110 leaded race gas in over lunch. There was probably 3 gallons of 93 unleaded in there. I hope that's not bad (no cats here). The car actually idles and runs a little smoother than before. SOTP meter says power feels the same.
It pings on 93 octane at WOT in 3rd gear. Doesn't seem to do it the lower gears. Haven't really seen the top of 4th gear since that's 120 mph or something. It didn't ping when the car was on the dyno. I think the base timing was 6* then. Might be 9* now. Going to mess with that and see what happens. Haven't made any 3rd gear WOT highway runs with the 110 leaded yet but I doubt it will knock.
My Formato prom's total advance at WOT is only 33*. That's probably the only reason I've made it this far on 93 octane.
