'84 Failed emission check
Old Nov 8, 2002 | 01:54 PM
jmh63's Avatar
jmh63
Default '84 Failed emission check
Ran the '84 thru the emissions check here and failed. It is running fine, getting 15.7mpg(city), no mods, get a little bit of pinging when I jump on it. Here are the results of the test:
HC(idle) was 690.1 PPM, the limit is 220.0-failed
CO(idle) was 2.10%, the limit is 1.20-failed
CO2(idle) was 7.94%
Any ideas on what to check...Thanks
Old Nov 8, 2002 | 02:38 PM
Starr's Avatar
Starr
Default Re: '84 Failed emission check (jmh63)
You could run a gambit of things...
Fuel filter ...when was it last changed?
O2 sensor...when was it last changed ?
Temp Sensor...when was it checked or changed?
IAC...cleaned and reset
TPS...needs to be checked for voltage
Fuel pump....should be between 9-14 PSI
Injectors....Both fireing and not leaking?
EGR...working properly....
Go here for added instruction
Click Here
One other thing...do you have any stored codes?
[Modified by Starr, 6:47 PM 11/8/2002]
Old Nov 8, 2002 | 02:39 PM
bogus's Avatar
bogus
running a little rich, eh?
sounds like the cat(s) may have given up...
did you warm it up completely before the inspection? I mean, drive it 20 miles or so? if not, that will have a negative impact on the performance of the cat.
give it a complete tune up, too...
Old Nov 8, 2002 | 02:41 PM
HWoods's Avatar
HWoods
When was your last tune up? Oil Change? You say no mods, is all emissions equip still on the car? My 84 failed Texas test once, replaced the oxygen sensor, new plugs, new plug wires and oil change and it passed after that. Did you drive the car for appx 20 miles before going to inspection? Or did you have just a short drive from home to the inspection station? You want the car well warmed up and in operating temp before going in for inspection.
Old Nov 8, 2002 | 03:14 PM
jmh63's Avatar
jmh63
Default Re: '84 Failed emission check (HWoods)
Thanks for the replies. I've had the '84 about 3.5 years, has 103k on it, it idles at 600-700rpm, it passed 2 years ago, fan relay is hardwired to run the fan all the time is the only thing I know that has been messed with.
Starr:
I don't know if any of that has been replaced or not before I got it. I have not check anything yet, will be working on it this weeked, how would I check for stored codes? Thanks for the link.
Bogus & HWoods:
It was warmed up, I had driven it about 100 miles before being check, all emission equipment is on the car & hooked up, I put plugs, cap, rotor, coil & changed oil about 6 months ago. Whats the best way to check a cat? Thanks
Old Nov 8, 2002 | 03:41 PM
Starr's Avatar
Starr
http://www.c4vettes.com/ecm.htm
Stick a horseshoed paperclip in A & B
Turn key on...do not start
Count the number of flashes your check engine light flashes. you will get a code 12 flashed 3 times x xx....x xx....x xx then any codes stored then three code 12s
Old Nov 11, 2002 | 08:27 PM
Slow LX's Avatar
Slow LX
Default Re: '84 Failed emission check (Starr)
I would definatly go with the plugs... A little additive does not hurt... Guaranteed to pass worked for me... :chevy
To '84 Failed emission check
