Throttle Body Question?
Old Nov 8, 2002 | 04:15 PM
CG77VETTE's Avatar
CG77VETTE
Default Throttle Body Question?
Can someone tell me if a stock '90 Throttle Body will fit a stock '86 L98?
Thanks for any help.
Old Nov 8, 2002 | 04:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Throttle Body Question? (CG77VETTE)
Though I don't know why, BBK shows one part number for the '84-'88 TB and another for the '89-'91 TB.
Old Nov 8, 2002 | 05:04 PM
CG77VETTE's Avatar
CG77VETTE
Default Re: Throttle Body Question? (65Z01)
65Z01,
That is exactly what I am finding also :confused: The gasket kit is the same part # though. I don't get it.
Old Nov 8, 2002 | 05:11 PM
65Z01's Avatar
65Z01
Perhaps the idle air flow paths differ; note that the FelPro gasket kits usually come with two TB to Pelnum gaskets.
Old Nov 8, 2002 | 06:09 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I don't know what the difference may be, but you are welcome to my old TB out of my 89. It is no good (shaft to body wear), but you could compare to your's.
Pete
Old Nov 8, 2002 | 06:15 PM
Fatt Vette's Avatar
Fatt Vette
The idle air paths are different, and as I recall the throttle linkage is different. The '86 is a straight pull and the '91 is progressive. I just put an '86 throttle body on a '91 engine in my '86 Z51.
Matt
Old Nov 8, 2002 | 08:37 PM
VetteRacer282's Avatar
VetteRacer282
The throttle linkage is different. Can be worked around with a new throttle cable (~$25). I will be doing this when I put my SR system on in the future.
If you know a good welder you could try to cut/weld the linkage between the two.
Matt
Old Nov 8, 2002 | 11:38 PM
CG77VETTE's Avatar
CG77VETTE
Thanks for all the replies. Basically, I was looking into buying a used TB from a '90 with 24k to keep as a spare if mine ever goes. I figured I couldn't go wrong for $50. If I ever need one I will probably buy a brand new one.
To Throttle Body Question?
