Best MAF Sensor?
Old Jul 19, 2019 | 01:44 PM
woodcrest's Avatar
woodcrest
Default Best MAF Sensor?
I believe I need to replace the MAF sensor on my 89, any suggestions? any to avoid? go with OEM specs, or is there an upgrade? I see new on eBay for about $80
Old Jul 19, 2019 | 01:46 PM
vader86's Avatar
vader86
If you've done the test to know you need the MAF, get the OEM part.
But you should also replace the two relays whenever you change the MAF. They are behind the battery on the firewall. They're cheap.
Old Jul 19, 2019 | 01:52 PM
woodcrest's Avatar
woodcrest
What test of the MAF?
Old Jul 19, 2019 | 01:54 PM
vader86's Avatar
vader86
There is a test procedure in the FSM to determine if the MAF is dying once you get Code 33/34.
To Best MAF Sensor?
