Injector Retaining clips???
Nov 8, 2002 | 05:55 PM
Where can a purchase the clips that hold the injectors in the fuel rails? I have a 91 with a MiniRam manifold.
Thanks in advance.
Phil
Nov 8, 2002 | 08:31 PM
Re: Injector Retaining clips??? (wheelsup)
The Last Detail (TLD) used to carry them.
Nov 8, 2002 | 09:21 PM
Dealer or last detail - P/N 17111267
Just happpen to have them on my desk :D
Nov 8, 2002 | 09:57 PM
Re: Injector Retaining clips??? (1MoorTym)
Never heard of TLD, but thanks for the GM #.
Phil
Nov 8, 2002 | 10:26 PM
Unless you're using Ford injectors, should really shouldn't need them it they're seated properly.
(I've got a Superramed motor with two missing clips. It's been fine for a year.)
Nov 8, 2002 | 11:48 PM
Re: Injector Retaining clips??? (RocketSled)
Not running any clips with my svo's. No problem so far..
Nov 11, 2002 | 01:34 AM
Re: Injector Retaining clips??? (corvette0096)
I got mine from Autozone. Part # 800-9411. $.99 each. Fits just the same as the original clip.
Nov 11, 2002 | 08:46 AM
I ran without them using my SVO injectors for quite a while. I went ahead and ordered them when I got some other stuff from Jeff Kopp once.
Nov 11, 2002 | 09:23 AM
When experimenting with an injector swap, I broke (4) clips. :sad: The side that has the clips do not leak. The other side wo/ clips leak. They are not the SVO type. They are LT1.
Thanks for your help.
Phil
Nov 12, 2002 | 02:37 PM
MSD sells some clips PN #2105. Think that they will fit. You can give them a call to be sure. :)
Nov 12, 2002 | 03:13 PM
Re: Injector Retaining clips??? (lead_foot)
Thanks everyone. :chevy
Phil
