700r4 two speed trans
Old Nov 8, 2002 | 08:05 PM
Sharky Guam's Avatar
Sharky Guam
Default 700r4 two speed trans
You read it correctly! My 700r4 trans in a vette that we recently acquired has only two speeds, first and second. When we first got the 30,000 mile car, it drove very nice and smooth. Then one day, it would only shift from first to second. It does this no matter what forward gear the selector is in. It stays in second until the rev limiter kicks in. Otherwise, it would probably blow up. There is no slippage and no grindings or burnt oil. Does anybody have any idea what may have suddenly went wrong? Perhaps the most intelligent vette enthusiasts would be able to guess what went wrong. Does anybody want to guess? :D
Old Nov 8, 2002 | 08:19 PM
BBA's Avatar
BBA
Default Re: 700r4 two speed trans (Sharky Guam)
The 3-4 clutchpak piston may be cracked. It needs a rebuild in short.
Old Nov 8, 2002 | 08:49 PM
Sharky Guam
Default Re: 700r4 two speed trans (BBA)
Anybody else have an opinion?
Old Nov 8, 2002 | 08:51 PM
TIMSPEED's Avatar
TIMSPEED
maybe it's a PG :D
Old Nov 8, 2002 | 09:37 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Sharky :cheers:
What year is it?
Can you adjust the TV cable?
Just another opinion, as you requested
Jack
Old Nov 8, 2002 | 10:04 PM
BBA's Avatar
BBA
Other than a broken 3-4 piston, I guess a stuck valve in the valve body could possible cause it...just very unlikely. You should take it to a trans shop. They can check the pressure on the 3-4 piston to see if it is being turned on or not. If you are right in saying the trans fluid is not burnt, there is definitely a pressure problem causing the 3-4 clutch pack to not apply.
BTW: What year is the car? Is it a 4L60E?
Old Nov 9, 2002 | 12:10 AM
wombvette's Avatar
wombvette
Check the Governor. The gears will sometimes strip.
Old Nov 10, 2002 | 11:02 PM
vader86's Avatar
vader86
Default Re: 700r4 two speed trans (wombvette)
rebuild time
To 700r4 two speed trans
