Guess the carnage!
Old Nov 11, 2002 | 10:37 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Guess the carnage! (scorp508)
Bueller
Old Nov 11, 2002 | 10:08 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Guess the carnage! (92TripleBlack)
I voted for a bad dream- he will wake up and find it running in the 11's.
Old Nov 11, 2002 | 10:33 PM
8388's Avatar
8388
St. Jude Donor '14
Default Re: (scorp508)
[QUOTE]Maybe the stuck open injector hydraulic locked the one cylinder...then on start up, boom...little chunks of cylinder wall and piston swimming in the foam bath that used to be the oil in the pan?
I really don't know. #4 was the open injector, #6 is the one coolant is flowing into.
But because of the open injector on # 4, fuel pressure had to be low, causing a possible lean condition for other cylinders. ( a possibility )
Old Nov 11, 2002 | 11:24 PM
WAY2FAST's Avatar
WAY2FAST
Default Hmmm
Think it is definately more than just a head gasket. :nonod:
Good Luck
:chevy
Old Nov 12, 2002 | 01:24 AM
ddsovy's Avatar
ddsovy
My wife thinks there could be multiple problems going on here (I usually listen to her (she is making me say this) ) She votes a bad block and bad fuel injector.
I reserve an answer because I need more information. OUCH!! OK. (don't ask) If your block was bad I Think you would have had some kind of symptoms and the same goes for a gasket. I think there is a problem with to much fuel in a chamber, maybe you have (or had) a leaking injector on # 6 humm SCORP! were running "special" FUEL??? You have been known to exceed the speed limit a time or two... Could the problem be fuel either locking up a piston while the engine was down or extreme detonating? Anyway, Good luck!
[Modified by ddsovy, 10:27 PM 11/11/2002]
Old Nov 12, 2002 | 01:34 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Guess the carnage! (ddsovy)
I am inclined to think that there is also a problem with the intake gasket. And possibly was the source of the water which may not be related to much of the damage. In fact, I am inclined to beleive that the foriegn matter originated from the manifold somewhere. Perhaps an incorrect bolt.
I just hope that you get it fixed. Finding that source of the problem is going to save you lots of sleep. Otherwise, I would use a crack detector and check the block and the head . I would not want to chance doing another tear down.
Good luck anyways!
Old Nov 12, 2002 | 01:46 AM
1bad85's Avatar
1bad85
From: livin life one hold my beer moment at a time Houst Tx
Default Re: Guess the carnage! (Sharky Guam)
Didnt you get the block out of an old van scorp?
Old Nov 12, 2002 | 05:51 AM
mm86L98's Avatar
mm86L98
yep... i'd go with a bad block, sorry scorp.. but then.. the stuff my wife calls food looks like that too :U
Old Nov 13, 2002 | 04:49 PM
95BLKVette's Avatar
95BLKVette
See this post
http://forums.corvetteforum.com/zerothread?id=430764 :D
