Electrical problem on my 96 CE Lt4
Old Jul 24, 2019 | 07:26 PM
staketruck05's Avatar
staketruck05
Veteran: Marine Corps
Default Electrical problem on my 96 CE Lt4
I have turn signals until I turn my lights to parking or all the way on, my right front signal doesn’t work i’m stumped bulbs are good fuses are good please help
Old Jul 24, 2019 | 11:02 PM
Kevova's Avatar
Kevova
Check for power and ground at sockets.
Old Jul 25, 2019 | 08:24 AM
jmeyer58's Avatar
jmeyer58
Check the ground on the RF. May be getting ground through the parking light circuit until you turn lights on. Good luck!
Old Jul 25, 2019 | 03:24 PM
jayjones's Avatar
jayjones
Are the turn signal bulbs dual element? I had a similar problem until I realized the bulb wasn't turned all the way in the socket to align the elements. Not on a c4 but still may apply
Old Aug 2, 2019 | 12:42 PM
KyleF's Avatar
KyleF
I believe they are like High/Low beam bulbs. Turn Signal is Brighter than Parking Lights. Not on a Corvette, but my 86 Tans Am had the same thing happen. It was the bulb inserted poorly. Quick fix.
If not in the socket poorly the socket or grounding of the socket could be bad.
To Electrical problem on my 96 CE Lt4
