Any transmission gurus give me a bit of advise. I had my 700r4 rebuilt because of all the reasons, and after about 2 months it is rumbling a little.
When in OD I floor it and it vibrates like going over train tracks. Tv cable is taught with throttle full and fluid is full. What should I ask him about? It does it most of the time.
The TC, valves or adjustments/ parts causing this. I have a warranty til May 2020 and want to head over to him next week.
Thx
Tell builder what it doing. Let them tell you why. Simplest would be c beam bolts loosened up. It's also possible it's not related to transmission repair...worn motor mounts or driveshaft dampner.
I read about the TC slipping because the pressure is not high enough. It feels like a clutch slipping and then vibrating, but will check all the others.
