runs rich...
Old Aug 1, 2019 | 03:15 PM
ran1099's Avatar
ran1099
1st Gear
Default runs rich...
I have a '93 LT1, runs and idles fine when cold. At operating temp. it runs rich with a slight miss under load...no codes..what should I look at?
Old Aug 1, 2019 | 03:54 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When the car is cold it is in "open loop" which means the O2 sensors are not controlling fuel scheduling...now when the car is warmed up and let's say your O2 sensor sees a "false lean" condition (a bad O2 sensor) the ECM will increase fuel injector pulse and hence the car will run rich.
