300 HP Crossfire engine?
Old Aug 3, 2019 | 02:03 AM
Chromis's Avatar
Chromis
1st Gear
Default 300 HP Crossfire engine?
What’s best and most reliable way to get 300+ HP from the Crossfire engine in my ‘84 ‘Vette? I want to up daily driving performance hopefully without going to forced induction. No nitrous thanks!! New intake manifold, port and polish job, new cam, larger throttle body, up fuel pressure or go to bigger injectors? Headers and/or exhaust? Some combination of these?
Can I do this with bolt-on mods, maybe for less than two grand?
Old Aug 3, 2019 | 02:45 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Here you go! With some money to spare!
https://www.ebay.com/i/133090226870?...CABEgL1O_D_BwE
Old Aug 4, 2019 | 12:09 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You can if you know how to port your own heads.
*Port the bejeesus out of your stock intake or buy a "Renegade" intake or use an Offenhauser or Edelbrock Cross ram intake with a custom lid.
*Headers and dual exhaust
*Injectors/fuel pressure/timing to "feed it what it wants"
^This should get you to ~250-260hp or so. I actually had a friend who had this combo, minus the headers and was making about 250 horse.
*Ported heads, or heads
*Mild cam
^Should get you to 300 hp or so. If you can tune the ECM (tune the stocker or swap to a '7747 ECM) you could get a lot more radical with cam selection and cruise right on by 300 hp easy, with CFI.
Below the intake it's a SBC. The intake's Achilles heal is the runners are too small in cross section. Port the hell out of them or get a Renegade/Offy/Edelbrock Cross ram intake to fix that. The BENEFITS if the CFI intake are that it's a nice, mid-length runner intake, so it's not RPM limited by it'a architecture, like TPI is. Get the runners bigger, and you got a good intake.
Old Aug 6, 2019 | 01:17 AM
Hot Rod Roy
Tom's got some good suggestions, but don't waste your time trying to modify those stock "624" heads. Here's some info for you, if you want to stay with (economical) iron heads. Of course, aftermarket aluminum heads would be a big help, but would probably bust your budget. Most aluminum heads don't have the exhaust crossover ports, if you want to retain the '84 EGR valve.
Old Aug 6, 2019 | 08:37 AM
GregMartin's Avatar
GregMartin
I’m doing a dyno run on mine next Wednesday so I can report back on what sort of HP alloy heads, cam, renegade and EBL ECM can deliver. The mathematics says you can’t make 300hp with two 61 pound injectors running at 13psi so I will be interested to see how much HP my crossfire makes. Depending on Wednesday’s results I might end up parallel plumbing my throttle bodies replacing the injectors with 454 80psi ones and installing an external regulator. The next step after that in boring out the throttle bodies to 2”.
Old Aug 6, 2019 | 09:47 AM
Krusty84's Avatar
Krusty84
Vortec heads, airgap intake and a carb. Mid 300s easily.
Old Aug 6, 2019 | 10:08 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^That's more work than the same 300 from the CFI system^
As a guy who's "been there and done that", I can save you a bunch of time and effort here:
1. Parallel plumbing does nothing. It's a total waste of time. It's treating an psychological problem, not an actual one. Same goes for the external regulator. It's eye candy, but doesn't do anything that the stock one can't or do (that it needs to).
2. You need 454 injectors
3. 2" TB's aren't needed and don't make any diff @ this hp level. All the bigger TB will do is make the throttle more sensative/responsive off idle. Which isn't a bad thing necessarily, but that's all/what it will do.
Old Aug 6, 2019 | 10:36 AM
Krusty84's Avatar
Krusty84
Originally Posted by Tom400CFI
^That's more work than the same 300 from the CFI system.
Maybe................ Way more potential though.
#ScrewTheStockGauges
Old Aug 6, 2019 | 10:58 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That's true. It is definitely way more potential. Is that what the OP needs?
Old Aug 6, 2019 | 01:43 PM
84 4+3's Avatar
84 4+3
I question how well a carb woul work under that hood though... gets pretty hot unless you go return.
Old Aug 6, 2019 | 02:09 PM
Jaye Bass's Avatar
Jaye Bass
Why not just go standard SBC upgrades with a Sniper EFI? Seems like the easy way to go...if you have the clearance.
Old Aug 6, 2019 | 02:55 PM
84 4+3's Avatar
84 4+3
If I were doing sniper I'd consider LS then. You can trick the crossfire pretty good to 300 or so HP but sniper is just a whole different level.
Old Aug 6, 2019 | 05:17 PM
GregMartin's Avatar
GregMartin
That’s music to my ears because the injectors are easy everything else is a pain in the ****.
thanks for the tip Tom.
Old Aug 6, 2019 | 06:01 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Look at people spending other people's money!
Totally. I bored my own TB's. Back in the day, I'd heard that you could got 2.03" (53mm) w/o cutting through the walls. Well, I went 53mm and was left with huge gaping holes in the walls. I made new walls with moldable epoxy, re-bored them again, then honed them smooth, then radiused the transition at the inlet side, so it was smooth. I installed 53mm plates and put it all together. It ran great, but didn't get me squat for power -at that power level. CFI-EFI did back to back on his car and gained nothing from the larger TB's.
I never wasted my time on the parallel plumbing, regulators or any of that. I threw in a 255 lph fuel pump (when I needed more fuel), and made my stock regulator adjustable, set it and it ran great.
Old Aug 6, 2019 | 08:13 PM
racerxl83's Avatar
racerxl83
Dart Heads (do not exceed 180 intake runner size), , ported and gasket matched intake, 1.6 roller rockers , Crane 2040 PowerMax cam, long tubes, x pipe and 375 gears. All on the stock computer. TPI fuel pump. She ran low 13s around 106 with bad traction
Old Aug 7, 2019 | 05:12 AM
GregMartin's Avatar
GregMartin
My regular is adjustable and I tried a walbro 190 litre per hour pump but I couldn’t get the pressure low enough. I blew out the return line with compressed air but I’m not sure what the problem is. I have a new return line but I haven’t fitted it yet. Anyway that’s a tale for another thread and another time. I like the idea of just changing to 80# injectors but I thought that they had to be different flow rates to compensate for pressure drop (although thinking about that it doesn’t make a lot of sense).
Old Aug 7, 2019 | 05:51 AM
84 4+3's Avatar
84 4+3
So long as the flow is available with the 80s, the regulator will maintain the same pressure.
To 300 HP Crossfire engine?
Old Aug 7, 2019 | 06:15 AM
GregMartin's Avatar
GregMartin
Yeah in theory that’s got to be right, I wonder why they were different from the factory?
Old Aug 7, 2019 | 09:55 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
As I x4 L83 owner I found this very helpful, always been surprised that its not a sticky here also?
L83 Tips
Old Aug 7, 2019 | 10:02 AM
84 4+3's Avatar
84 4+3
At 80lb/hr you're using almost 50% more fuel at 13 psi (and 90ish duty cycle) so if the 84 pump is tapped out 13psi on the 64s then it'll drop pressure on the 80s. Otherwise regulated restriction is constant unless you're running enough fuel to build up tons of head... ie the return is too small for the flow rate returning.
