Headlight problems
Old Aug 4, 2019 | 07:24 PM
Shelton Polk's Avatar
Shelton Polk
1st Gear
Default Headlight problems
I have a 96 c4 my left light does not pop up replaced everything but the switch. IT a little bit down and a little bit up when I turn the lights on and off, oh the right side works fine. Could it be a shorted wire or bad light switch. Help me or point me in the right direction
Old Dec 12, 2019 | 01:14 AM
Furioso's Avatar
Furioso
No answers? I have similar problems.
Old Dec 12, 2019 | 10:44 AM
Kevova's Avatar
Kevova
Headlight motors each have fuses. There are several connectors involved. To start you need to see if you have power and ground to effected headlight. If you have FSM or similar , component locator will discribe location of connections. If not you will need to "chase the wires"
To Headlight problems
