smoke
Old Aug 5, 2019 | 10:26 PM
doityourself's Avatar
doityourself
Default smoke
96' c4 would not start bad ignition switch ,bought new one and installed , with battery disconnected new switch seams good , I got lock and key comes out , and spring back when trying to start [that's what was missing from old switch the spring back ] put steering column back in car hook up battery headlight's cycle up and down and flashers are on ,turn flashers off turn key to on lites come on dash and I heard no crank just heavy smoke from ignition switch [lower column] when tried to start so key off and disconnect battery . had no trouble with wiring before I guess a bad switch ?
Old Aug 8, 2019 | 09:10 AM
95LT1ZF's Avatar
95LT1ZF
Sounds like you may have pinched one of the wires and grounded it out when you were putting everything back together. I've done that a couple times over the years installing auxiliary lights. Pull the column back apart and look for cut wires, probably near the column mounting bracket. .
