Oil leak !!!
Old Aug 7, 2019 | 09:35 PM
Tvette99's Avatar
Tvette99
Default Oil leak !!!
Hey guys i own a 1990 vette i cleaned up the engine etc and ran it for a few hours to try and pin point this leak. Sadly im thinking its a head gasket can you confirm for me please with the attached pics ??? Its right below these two bolts 😭
Old Aug 7, 2019 | 11:19 PM
aklim's Avatar
aklim
The Valve Covers and China Wall are my first suspect when looking for an oil leak on an L98. Never had one that sealed well for any length of time whether I did it or professionals at the speed shop or a dealership. Spray it all off with brake cleaner, dye the engine and see what gives.
Old Aug 8, 2019 | 12:44 AM
compyelc4's Avatar
compyelc4
Looking at the dry head area above the leak, I suspect head gasket and not valve cover. If valve cover you would find oil seepage from bottom of valve cover to head gasket area you are showing.
Old Aug 8, 2019 | 08:03 AM
C409's Avatar
C409
..... FYI … There is NO pressurized oil passing through the cylinder head gasket … only coolant (minimal) and compression/cylinder pressure are exerting any force upon the head gasket aside from those ARP bolts …..
Old Aug 8, 2019 | 08:34 AM
RWDsmoke's Avatar
RWDsmoke
Exactly! There is no oil going through the head gasket. My bet is those "made in China" valve covers.
Old Aug 9, 2019 | 04:42 PM
Tvette99's Avatar
Tvette99
Default Sadly
It is definitely not the valve covers thats what I suspected at first the picture shows the best angle i could get its worse near the back of the engine. So what am I looking at just a leaky gasket ?bots definitely not valve covers I have no milky oil and the car does not over heat ? I couldnt see any oil in the coolant is it possible just the gasket is toast or am I looking at even more money warped heads etc... Was going to pull the spark plugs when I get home tonight
Old Sep 7, 2019 | 06:04 PM
TA's Avatar
TA
Did you ever figure out where the leak was coming from?
Old Sep 10, 2019 | 12:00 AM
Tvette99's Avatar
Tvette99
Yeah its definitely the headgasket... But from what im reading oil doesnt pass through the headgasket so its a coolant leak ????
Old Sep 11, 2019 | 08:47 AM
C409's Avatar
C409
….. If that "dampness" is making its way to your garage floor , it should be pretty obvious whether its oil or coolant ? …..
Old Sep 14, 2019 | 07:32 AM
BLKMAMBA's Avatar
BLKMAMBA
Horsepower sweat
Old Sep 24, 2019 | 03:09 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
OP, have you lost excessive oil (as in via the dip stick) from driving around? Spark plugs look good?
Old Sep 24, 2019 | 08:35 PM
Mity2's Avatar
Mity2
ive seen the oil from chinawall leak seep its way all the way around to front(i.e. My car...). when was intake gasket was last replaced?
To Oil leak !!!
