Old guy, first Vette. I just purchased a 96 one owner with 50k miles. The owner died a few years ago and it was not driven much thereafter. It was checked out by my mechanic, and besides general maintenance needs a water pump and similar obvious minor items. He is very good but not a Corvette expert. In your experience what are the other not so obvious items that should be checked out?
It's always a good idea to inspect, and potentially replace the optispark when doing a water pump. The seals on the timing cover often fail, although the '96 is the better later design, they still leak.
A new water pump with the weep hole mod, optispark, and some seals will last another 50k.
Rear tie rod ends are known to freeze up. They should be inspected.
Cbeam bolts should be inspected, sometimes they losen, which can lead to cracked transmissions.
Other than that typical things you would inspect on any vehicle.
Do you have the Service Records? Other than a Good Fuel Flush out and new Fuel Filter a Fresh oil change which expect it has already gotten. If you have No Knowledge of a Tune up put one in at 50k it wouldn't hurt. If it's a Good Runner, Enjoy/Drive.
Like above Mentioned there can be Problems but @ 50k I think your car was a Fair weather car and unless something Breaks I wouldn't be looking for Problem but Fix as soon as they Appear.
As Aklim suggests be sure to replace every fluid in the vehicle and check the hoses as older hoses are known to dry rot and crack. Replace the serpentine belt and all the filters that are easily changed. The air and Fuel filters especially and check the date codes on the tires to be sure they are still safe.
I would probably install a new O2 sensor just to be safe as the old one has corroded by now and will have a limited life due to its age. You could wait on this if it has not sat long but if it was more than five years then I would seriously consider the new O2 just to avoid any problems.
When I saw this post I thought of you Aklim as I was going to suggest replacing the Opti or getting a spare to have on hand for when it does break. I figured I would catch the wrath of the LT1 owners if I brought up the issues of the Opti. The optical firing parts are fine with me but where they put it is what I have trouble with. Somebody should have scratched their head a bit longer on that one. I would have used a crank trigger over the Opti and its location. But that is just the way I would have done it.
Best regards,
Chris
P.S. Welcome to the World of Corvettes and especially to the Corvette Forum!
Best regards,
Chris
All fluids should be dumped. Trans, brake, power steering, etc. If it flows, it goes.
I get nervous about dumping trans fluid in older automatics. When I had a shop a lot of them never moved again.
I realize that the trans is already shot in those cases, and the new fluid or trans flush is simply flushing out all the friction material that was limping it along, but still lol.
Crank triggers fail all of the time, but they usually take 10 minutes to replace.
The Opti is also a cam sensor, which is needed on the sequential cars.
We bitch and complain because it's significant labor to replace an opti. The location of the water pump weep hole is problematic, the water pump drive is problematic and leads to seal failure, and so on.
I'm running a crank trigger in my firebird but it's wasted spark + batch fire. My C4 is still opti.
-- Joe
I would drop the pan to get an idea of whether I need a new trans or not when it is an unknown. Obviously, we both know that great service today isn't going to make up for the last 10 years of neglect but people still hope for a "Hail Mary" to pay off since it is cheaper than the right fix (new trans). If the pan comes off with a lot of silt, I know that they might as well get ordering a new trans. If the fluid is looking brand new, see above. They probably changed it to impress the buyer. If it doesn't look perfect, I'd continue the flush and filter process because I think there might be something usable for a while.
Thanks guys. All fluids, filters, belts, and hoses are on the list plus plugs and wires. The additional items you mentioned will go on the list to check. Car was driven every couple of months in the past couple of years, and fortunately my mechanic is familiar as he recently replaced the alternator and belt.
1. 1996's have 4 O2 sensors, 2 before and 2 after the cats.
2. There is a gentleman who rebuilds OptiSparks. If you price out the cost of an MSD rotor and cap, you will see that his price is most reasonable. Here is his link on eBay, if you search
out Optidoctor here on the forum, you can find out how to contact him off eBay. MSD components, in conjunction with a refurbed oem unit seems to be the best way to go.
