Hi All - This is my first post so hope I get it right. I have a '96 LT4 w/26K miles, garage kept. She has always started on the first crank! Never a problem. Performed as new! Went to start her last week and she would crank, but not start. I DID NOT hear the 2 sec. Priming Sound when I turned the key to ON, which was always audible. So, here is where I am; I cranked her for about 10 sec. The oil pressure climbed to the 1st. "tick-mark", but did not start! Given the Oil Pressure Switch and the Fuel Pump Relay are wired in parallel, I expected she would start. Hard to believe both circuits are faulty. No pressure in the fuel rail. Anyway, checked all the fuses - Ok, Ran OBD2 Scanner - No Codes, Inspected the water pump for leaks - No Leaks, Opti was dry, Checked for spark at the coil - Ok, Measured Ignition Control Module plug (Pins A & D to Grd. - each 12vdc, Pin B to Grd, - ~1vac), thinking the Opti & PCM/ECM are ok. Any recommendations you may have are greatly appreciated. Thx.
Maybe your fuel pump? Have a helper spray starting fluid into the intake and see if it fires up. If it does check for power at the pump.
no, no, no Try the five dollar solution first (or in the case of a corvette the $25 solution). Its probably the fuel pump relay, its located under the right side lower trim panel. Or the fuel pump switch, located at the back of the engine (along with the engine oil pressure sensor). Easy enough; and by corvette standards, inexpensive, and on a 23 year old car should probably be replaced as a matter of course, regardless of mileage. After that, if it still won't start, and you're certain its a fuel issue, then look at the fuel pump. Good luck.
I sprayed starter fluid into the intake. Engine didn't sputter! I'm not convinced that the 1.0 vac (Spec. 1-4 vac) measured on Pin B to Grd. of the Ignition Control Module Plug while cranking the engine, is typical. Has anyone else measured this voltage?
I'm all about inspect/test the easily accessible areas that make sense and not just exchange parts. Since the oil pressure sensor and relay are wired in parallel, and it wouldn't start, suggesting they are both bad makes no scense. That said, I think I can measure the voltage at the oil pressure sensor? If the voltage is present I'll move to the Fuel Pump Switch, Relay and FP and keep you posted. Thank you.
If you didnt hear the pump prime, I suspect the pump.
Throw a pump in it, they aint hard to change.
If the oil pressure sensor & relay are in parallel, it seems likely the pump is bad. Going to check output of oil pressure sensor, it should be there, to further convince myself. Thanks!
May not help, but any vehicle with an opti ....... suspect the OPTI.
Owned LT1s for 15 years. Got really tired of changing out the opti.
Don, Hoping its not the Opti...have good spark and believe the correct signals on the ignition control module plug, which I believe suggests the Opti & ECM/PCM are ok..However, it is on the list. Thanks.
One positive item you have going for you is your opti is vented. None of my optis were vented.
No pressure at the fuel rail...Can't hear the 2-3 sec. priming occur.
Well! I gave her a couple more shots of ether & this time she started...but did not continue to run. Oil pressure was well above 4 psi. No fuel pressure at the rails. So, does that say the ECM/PCM & Opti are Okay? Thinking I need to measure for 12vdc at some point after the Oil Pressure Sensor & FP Relay. Is there any point less intrusive then the Fuel Pump harness on top of the tank? Thx..
Well, you were correct....the ether treatment got her started but wouldn't continue to run. Eliminated everything suggested, for which I was grateful for everyone's help. Checked for 12vdc at the FP plug and had it for 3 sec. after turning the key to ON! Imagine that...I'm assuming I just need a new fuel pump. Any recommendations on a brand? Thx.
Now if your fuel hanger and sending unit are nasty, I would replace those while I was in there, ~$150 or there abouts.
Thanks for the recommendation, however the only part that has been upgraded is the headlight gears - all original LT4! So, want to stay with AC Delco "pump". Do you know the Model #? There seems to be at least two (2) types. Confusing? I also want to replace the Fuel Strainer and some pumps include it and others don't. Thx.
My 96 is basically the same, 99% original and stock.
Rock Auto lists the EP376 Delco pump as being applicable for the 96. They have them in stock.
They also seem to list an AC Delco sender assembly(hangar, sending unit, etc...) as available if you need that also.
Have ordered the Pump/Strainer EP376, TS17) tank gasket and neck filler..hoping to get it completed this weekend. Thanks for your help! Will let you know the results...
