1988 Climate Contoll Issue
(I tried 8x's to attach a 25kb pict but, this site has problems again!)
Problem with a 1988 Corvette Coup...I haven't used the car in a bit and usually start it 2x's a month to keep things lubed and charged up, etc.....I wound up having to jump start the car with battery charger (starter-charger), 2-20-200) and I let it run for a bit.
I had a reason to use it and noticed that the ELECTRONIC CLIMATE CONTROL (CC) unit was acting up.......I could raise the displayed temperature (with the "up" button) in the digital window up as usual but, could not lower (with the "down" button) the temperature display at all, no matter where it was set at!
I have full control of the fan and all that but, not lowering the temperature...I have disconnected/bypassed the heater core quite some time ago in anticipation of replacing the core as I did my evaporator - just to be safe, and all still worked well after that.
I have read some info on replacing the "face" but, that is NOT an option as of yet...Is there a way to "re-set" the "CC" by a series of button pressings?...
I remember seeing that someplace but, not able to locate it......I HAVE disconnected the battery for 30 min with no change of issue....I also have NOT pulled the unit from dash to check on possible corroded contacts....
I recall reading a thread where some have sent their controllers in the have each of the terminals hard-wire soldered to each of the controller face connectors. Unnecessary overkill in my opinion, but a solution that also works.
Press the Ext. Temp. button.
While pressing the Ext. Temp Button, press the Auto Fan button and then release it. Then release the Ext. Temp. button.
a -00 should appear. - indicating what Mode is displayed.
Mode 1 is Program number
Mode 2 is in vehicle thermistor
Mode 3 Ambient correction
Mode 4 Blower number
Mode 5 Outside thermistor
Mode 6 Feed back pot position
Mode 7 Calculated door position
Mode 8 System faults
Mode 9 Ratiometric feedback position
Mode 10 Full hot position
Mode 11 Full code position
Mode 12 Software version
To change Mode # press the Warm button.
To see the value in that Mode # press the Cool button.
A system fault will be indicated by a flashing indicator. If there is a problem with the ambient sensor, in
vehicle sensor, or the feedback potentiometer, the Ext. Temp. indicator will flash for about 60 seconds,
upon ignition ON. The flashing indicator will reoccur upon ignition ON until the system problem has been corrected.
Hope this helps!
Red--
